Thump just after starting engine
Old Feb 27, 2006 | 11:18 AM
Jwinterstein's Avatar
Jwinterstein
When I first start my 04 Larriat - after about 20 seconds or so there is a "thump" that sounds as if it is under the passenger side floor board or dash area. I thouht at first it was a heater "door" closing or opening but now am not sure. Any ideas?
Jim
Old Feb 27, 2006 | 12:54 PM
alpcrc's Avatar
alpcrc
Me Too
Jim-With you on the "thump". My '04 XLT Scab 4x4 does the same thing. Stealership can find nothing.
Old Feb 27, 2006 | 11:04 PM
xtrm1stang's Avatar
xtrm1stang
Try starting your truck with the a/c in the OFF position. See if the noise is still there, then turn the a/c on and see if it happens within 30 seconds. The a/c compressor will make a pretty loud thump/bang noise when it is first engauged after sitting. This is normal and is caused from the freon setteling in the ac compressor. if you drive with the ac off first, once the trcuk is warm it will most likely not happen, even if the ac has not been on yet.
Old Feb 28, 2006 | 08:25 AM
poolmanj's Avatar
poolmanj
Mine does the same thing.Don't think it has anything to do with the A/C comp.I think it is more like one of the blend doors resetting it position but I am still searching for the answer.
Old Feb 28, 2006 | 12:56 PM
Jwinterstein
Thanks, guys - my impression too was that it was a blend door. I will try the suggestion, however.
Jim
Old Mar 2, 2006 | 09:31 PM
Bozack's Avatar
Bozack
mine the same / no clue & have wanted to post about this BUT had no idea what to say - THANKS
Old Mar 2, 2006 | 11:44 PM
edgl's Avatar
edgl
My last few Ford trucks did that. My 06 F350 does the same thing. It is the A/C system. It comes on after you start your truck, in about 15 seconds, if you have the A/C on.
Ed G
Old Mar 3, 2006 | 05:52 AM
Q'man's Avatar
Q'man
This happened to me yesterday about 5 times while running. Sounded like the ac coming on and off when on max; and I never start the truck with the AC on. When I turned the dial to panel setting it quit???
Old Mar 3, 2006 | 05:57 AM
06supercrew's Avatar
06supercrew
If you have the defroster on the AC compressor is also on (to dehumidify the air).
Old Mar 3, 2006 | 03:13 PM
kize's Avatar
kize
It is the fresh air blend door closing. Starting the truck up creates vacuum, drawing the door closed.
