tachometer
Old Feb 27, 2006 | 11:16 AM
wethugin87's Avatar
wethugin87
tachometer
how would i hook up a tachometer im my 96 ranger.?
Old Feb 27, 2006 | 03:16 PM
RangerPilot's Avatar
RangerPilot
How many wires you got on it? I'm assuming it's an electrical gauge. What engine do you have?
The general suggestion is to mount it, hook up the power, lighting, and ground wires (power to anything that comes on with the key being turned to ON, lighting to anything else that is lighted by the main light switch unless you want it controlled differently, and ground to some sort of ground...). I'm going to suggest you allow a shop to hook up the actual signal wire, as there are several thousand volts down there you're playing with. Safer for you.
Old Feb 27, 2006 | 03:23 PM
Bob Ayers's Avatar
Bob Ayers
WHAT?????? The TACH signal is generated from the PCM, there is NOT several
thousand volts coming from the PCM!!!
Old Feb 27, 2006 | 03:31 PM
john112deere's Avatar
john112deere
Is this an aftermarket tach, or did you buy a Ranger gauge cluster with a tach from a junkyard?
Old Feb 27, 2006 | 03:34 PM
Tiggie's Avatar
Tiggie
Standard tach's I believe have a black wire and a green wire. The black goes to a ground, the green you can splice into the PCM, which should be mounted on the passenger side firewall/fenderwell. You will need to splice into pin number 48, which will be a brown or tan wire with a yellow stripe, to obtain your engine RPM signal.
You may try searching the forums, I have no hands on experience with wiring an aftermarket tach into a '95+ Ranger.
Old Feb 27, 2006 | 04:34 PM
RangerPilot
I always was told it was hooked into the ground for the coil? My apologies.
Old Feb 27, 2006 | 04:41 PM
Bob Ayers's Avatar
Bob Ayers
That was true many years ago with "point type" of ignition systems, and the early electronic ignition systems. With Ford's DIS, and EDIS, the tach signal
is generated from the PCM.
Old Feb 27, 2006 | 05:35 PM
RangerPilot
Ah this is what that PM was. Good to know I'll keep that in mind.
Guess I've been lookin' into older engines a little too much lately. Thanks Bob!
Old Feb 28, 2006 | 02:17 PM
wethugin87's Avatar
wethugin87
yes it is an aftermarket tach. and its for a ranger with a 2.3L. and i just got a guage bezle and its going in that and i need to know how to wire it..should i bring it somewere or is it easy enough for me to do.?
Old Feb 28, 2006 | 03:15 PM
skier-24's Avatar
skier-24
What do the directions say about picking up a signal?
Old Feb 28, 2006 | 05:17 PM
RangerPilot
you can do it yourself. You'll just have to run a wire from the signal wire for the tach (probably came as a green wire) to the signal wire going to the Powertrain Control Module or PCM. As tiggie said, this is a brown or tan wire with a yellow stripe. You can probably just get one of those "T" connectors that allows you to go right into the wire. Quick and easy.
Old Mar 1, 2006 | 12:08 AM
irishguyincc's Avatar
irishguyincc
I'm going to sorta hijack this thread. I would like to install a tach in my '87 Ranger and would like some info on how to go about it/what tach to use. My truck has an electronically (TFI) controlled distributor. It's the 2.3 with a 5 speed if that matters. My dash layout is the one with a gauge cluster on the left and a spedo on the right. I always wanted to have a tachometer but don't really know anything about installing one. Any info would be appreciated.
Old Mar 1, 2006 | 08:25 PM
Ken00's Avatar
Ken00
Irish,
Since yours is different from a 96 why don't you start your own thread.
