Wiring Prob
Old Feb 28, 2006 | 02:30 PM
1975Ford's Avatar
1975Ford
Try disconnecting the flashers under the dash. and check for volt pulse at the ACC at fuse box. The disconnect the ground cable at the battery and then disconnect the harness at the voltage regulator, reconnect batter and check for pulse at the ACC at the fuse box. Did any of these stop the flashing?
Make sure you disconnect the ground cable when you reconnect the harness at the voltage regulator.
Old Feb 28, 2006 | 02:43 PM
User 71024's Avatar
User 71024
is there an echo in here?
Old Feb 28, 2006 | 03:01 PM
1975Ford's Avatar
1975Ford
Yeees, Yeees, yees, yes, yes
Old Mar 7, 2006 | 11:02 PM
Rancho*Ryda's Avatar
Rancho*Ryda
Alternator?
hey put alternator in truck ? no charge? people saying i have to EXCITE it? and where do wires go and what color?
Old Mar 7, 2006 | 11:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
No need for any excitement or polarizing on an alternator unless you are referring to the field coil connection. Refer to the wiring diagrams in your service manual for the connections. Service manuals can be purchased at any parts store and needs to be the very FIRST thing you buy for your truck. OEM manuals on CD are available from MotorHaven at the online store here or other vendors. Check Blue Oval also.
Old Mar 8, 2006 | 12:38 PM
Mil1ion's Avatar
Mil1ion
Eric maybe you can merge this thread with her original
Ryda,
There is an illustration in my gallery.
Would told you to excite it ?
Probably some really OLD guy that forgot that only sometimes Generators (Pre-65) need exciting.
Old Mar 8, 2006 | 01:15 PM
ford390gashog's Avatar
ford390gashog
unless you went with a gm 10 si alternator which does use a wire to excite it.
Old Mar 8, 2006 | 10:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
Threads merged... -again
Shutech
Apr 21, 2015 09:31 PM
036.0stroke
Sep 25, 2013 10:07 PM
harris2108
Nov 17, 2010 05:32 AM
DDuBB
26
May 27, 2006 07:41 PM
