Help! My replacement hood doesn't fit!
Old Feb 26, 2006 | 08:50 PM
richdail's Avatar
richdail
Question Help! My replacement hood doesn't fit!
I bought a 77 ford hood and grille assembly for my wrecked 79 F100.
Everything went reasonably smooth, except there are no holes to screw the headlight assembly to, which I knew and was prepared for.
But then I finished up and closed the hood and it won't latch! The hood "bar" is a full inch in front of the latch! I tried adding a spacer to the latch mechanism but it still won't reach. The previous owner hit a tree on one side of the truck, so it shouldn't have affected the middle of the truck, and it doesn't appear to be bent.
I'm at a loss as to what to do now. Can a professional body man even fix this problem?
Old Feb 26, 2006 | 09:07 PM
Mil1ion's Avatar
Mil1ion
I thought the headlights were in the grill area?
Park/Turn signal lights in the hood.
Where did you get the hood from ?
Old Feb 27, 2006 | 06:17 AM
richdail's Avatar
richdail
I got the hood from a junk yard. It was still on the truck and looks to be in undamaged condition. I believe that the radiator guard on my truck must be pushed in, though it does not look like it with the naked eye. I don't know how you would pull it out.
Old Feb 27, 2006 | 09:37 AM
Mil1ion's Avatar
Mil1ion
Probably with a come-along and a concrete /steel post
How well does the hood align up with the fenders ?
GreatNorthWoods
15
Feb 29, 2016 06:54 PM
Wayne Waldrep
21
Aug 3, 2014 05:25 PM
ohbrian
Sep 23, 2013 01:05 AM
GEugeneS
Sep 22, 2013 11:35 AM
