Sponsored by: Real Truck
Ratio...........
Old Feb 26, 2006 | 04:32 PM
Vinford's Avatar
Vinford
Ratio...........
I just bought a 02 F-350 4x4 Crew Cab Shortbox.
Can anyone tell me how to find the rear end ratio or what I need to post here for someone to be able to tell me?
Thanks.
Old Feb 26, 2006 | 06:57 PM
steve(ill)'s Avatar
steve(ill)
i believe there is a tag on one of the rear alxe pan bolt nuts. get the code there.
Old Feb 26, 2006 | 07:19 PM
jcstratt's Avatar
jcstratt
Sticker on the drivers door has the axle code. Look here to decode it. https://www.ford-trucks.com/article/...r_Decoder.html
Old Feb 26, 2006 | 07:59 PM
Vinford's Avatar
Vinford
thanks but that link doesnt seem to deal with F-350's
Old Feb 26, 2006 | 09:07 PM
jcstratt's Avatar
jcstratt
http://www.drivetrain.com/Fordtrkratio_posidata.html
Old Feb 27, 2006 | 06:39 AM
BFR250SD's Avatar
BFR250SD
The tag on the axle housing should have your ratio on it.
Should read something like 3L73 (3.73 LS), 4X10(4.10 Open dif), 4L30 (4.30 LS), etc, etc.
If it has an L in it, you have a limited slip rear end. If it it doesn't have an L, you have an open dif. The number are your ratio, 3.73, 4.10, 4.30, etc
