Can anyone ID this Holley carb for me?
Old 02-26-2006, 03:08 PM
beachrat's Avatar
beachrat
beachrat is offline
It came off an '87 Bronco and the #'s on the horn are E3TE-9510-RD.
But,I have no idea what this means.
I'm trying to find out if it's original or not.
Old 03-02-2006, 04:30 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
E3T means 1983 Ford Truck. 9510 is common for a 4180 Holley 4V 600cfm.
No it isn't original on the 87. That would be an E7TE-9510-??
Old 03-02-2006, 04:56 PM
Jharger's Avatar
Jharger
Jharger is offline
Why can't a 87 truck come with a carb originally part numbered in 1983? If the carb didn't change, would it not have the same number? Does Ford create new part numbers every year even if the part stays the same? I've seen the magic decoder rings before but not sure how Ford applies them.
Old 03-02-2006, 05:42 PM
beachrat's Avatar
beachrat
beachrat is offline
Thanks for the info,fellas.
When I said "original",I guess what I really meant was,"compatible" for a 351W.
When I see you guys throw around numbers like,"4180",I get confused.
That number is nowhere to be found anywhere on this carb,and it had me wondering about how you figure out which carb is which.
Is there a chart that explains it all for the novice?
Old 03-02-2006, 06:14 PM
Jharger's Avatar
Jharger
Jharger is offline
4180 is holley's part number. Try looking it up on their web site. The encripted part numbers are Ford's.
Old 03-04-2006, 05:26 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
4180 is the series number. 4180 is an OEM series carb with annular discharge booster venturies in the front, sealed idle mixture screws in the baseplate instead of the metering block, vacuum secondaries, electric choke, and exact size jets (usually 62 2) which means they are exactly 62 for emmisions reasons.
Due to emissions calibrations, they must be calibrated for each model year.
It should work OK on your 351W.
Old 03-05-2006, 04:19 PM
beachrat's Avatar
beachrat
beachrat is offline
Thanks LxMan1.
I'm going to do a rebuild,and new choke pull off on it and wanted to make sure I wasn't wasting my time and money.
I'm assuming I can buy a new electric choke too,correct?
Old 03-07-2006, 03:35 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Yes, Any Holley dealer should be able to fix you up.
12gaugeCharlee
New Member Introductions
01-24-2018 10:05 PM
ceskipper
6.4L Power Stroke Diesel
05-12-2017 07:08 PM
Havecooker
1999 to 2016 Super Duty
04-09-2017 11:07 AM
beals
06-28-2016 04:12 PM
Jaime74656
12-25-2015 08:53 AM
Quick Reply: Can anyone ID this Holley carb for me?
