po401 code
Old Feb 26, 2006 | 09:41 AM
formermustang's Avatar
formermustang
po401 code
What is the first thing to check on a 2.5 L 4 popper
Old Feb 26, 2006 | 08:03 PM
Ken00's Avatar
Ken00
You didn't say what year but I would suspect a DPFE sensor.
Old Feb 27, 2006 | 04:32 PM
formermustang
oops It's a 99. Is there any way to do a resistance or ohm check to see if it is bad
Old Feb 27, 2006 | 04:56 PM
Bob Ayers's Avatar
Bob Ayers
Check out this URL, Joe (Rockledge) did a great job documenting a test for the DPFE sensor:
http://rockledge.home.comcast.net/Ra...tage-Test.html
Old Feb 27, 2006 | 05:54 PM
formermustang
Thanx I'll get my butt out there in the morning and chek it. I was gettin worried cuz they have a tendincy to make that kind of stuff solid state which you can not test
Old Feb 27, 2006 | 05:56 PM
twinarrow99's Avatar
twinarrow99
DPFE and possible EGR
Yes, agree with the above 100 percent. Had a P0401 code last month. I replaced the DPFE on my 99 2.5 Ranger after the voltage test showed it was bad. Also, as I had 82000 miles, replaced the EGR to be on the safe side. Also, when you replace the DPFE, blow some compressed air to clear out any crud in the two exhaust hose connections. Works like a champ!
Old May 22, 2006 | 07:07 PM
oldgoat49's Avatar
oldgoat49
The test says to leave the harness plugged in for the test. How are you to get a reading unless you stick a pin through the harness to attach to?
Old May 22, 2006 | 08:01 PM
Rockledge's Avatar
Rockledge
Many people do just that.
Old May 23, 2006 | 05:16 AM
Bob Ayers's Avatar
Bob Ayers
A lot of DVM probes are sharp enough to make contact through the wire insulation.
