6 postion chip selector location ????
Old Feb 27, 2006 | 03:35 PM
PowerStrokeMe's Avatar
PowerStrokeMe
You have to drill a hole and cut some of the molding behind the old ashtray since the back of the **** is so freakin big but I like the location. Have to lean over a bit to turn the **** but its pretty easy, unless you have a big hand. You can look in my gallery if u wanna.
Old Feb 27, 2006 | 06:14 PM
Orezona's Avatar
Orezona
You know I've wonderd about that. Today's technology, 6 programs in one truck's chip, and that's the most hi-speed, smallest switch that can be used?
Old Feb 27, 2006 | 07:53 PM
the1mg's Avatar
the1mg
Talking
I hate cutting holes ANYWHERE there ain't supposed to be one. If you haven't bought gages yet (I'm sure you will pretty soon), you might consider a Quad pillar pod?? I made a pod insert to match my gage bezels out of aluminum and polished it to a satin finish, slipped it in with the switch installed and I was done . I bought a lighted selector dial from BlackCloud, but before I install it I'm going to make a custom face plate to show MY selections ie. S,40,60,80,100 & 120 instead of 1,2,3, etc...
No-one but no one drives my truck so I figure whats the point of hiding it, just makes it a PITA to use. Hell I want to show it off !
I'll post new pics after I install the lighted dial
Old Feb 27, 2006 | 07:55 PM
Orezona's Avatar
Orezona
Now that's nice. Does it illuminate with the gauges? Very nice....
Old Feb 27, 2006 | 07:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
now, that is some good stuff there MUY BIEN!
i left you some reputation pointes the1mg
Old Feb 27, 2006 | 08:10 PM
the1mg's Avatar
the1mg
Wink
Thanks!
It will when I'm done . I'm going to silk screen my font onto white translucent abs material. With green leds (off BlackClouds dial) lighted from behind it'll look just like my other gages
Old Feb 27, 2006 | 08:35 PM
jtharvey's Avatar
jtharvey
I'm with you on that one. Nice setup too.
Old Feb 27, 2006 | 08:44 PM
sgrol's Avatar
sgrol
I'll add a twist to the mount discussion. I mounted mine (without the ****) into a piece of pipe secured to the fuse panel under the kick board. I then drilled a hole to the left of the steering column. I removed the ****. secured it to about a three inch long piece of transmission cooler steel line. On the open end of the steel line, I expanded the id to fit the stem of the switch. Then I heated the line and beat a flat spot in it.The **** attached to the steel line, fits through the drilled hole and mates up to the hidden switch. I have an idle only setting on my chip and if I leave the truck idling unattended, I can turn the switch to idle only, pull the stem and put it in my pocket while away from the truck. If anyone steals it they won't go far or fast. Or, if I let someone else drive the truck, I can set the switch to stock, remove the stem and they have no way to change the setting. A little more involved but very effective.
Old Feb 27, 2006 | 09:41 PM
PowerstrokeJunkie
damn! got any pics of that!!
Old Feb 27, 2006 | 11:43 PM
PowerStrokeMe
That is a good idea, very nice I am the only one to drive my truck but I wanted to hide mine for emission time
I think you just bought a couple of decals from me off of ebay. Small world?!?
Old Feb 28, 2006 | 06:04 PM
the1mg's Avatar
the1mg
That was you ?? I didn't make the connection! By your ebay name I thought you had a grudge against PSD's (powerstrokethis)
By the way I'd like to get another of the same decal...gave the extra to a friend!
Old Feb 28, 2006 | 11:47 PM
PowerStrokeMe
Yep that was me My name on ebay is powerstrokeme00. I would die before I gave up my stroker!
You can send me a pm to do the details. I still have 5 decals left!
Aaron
Old Mar 1, 2006 | 08:03 AM
  #28
sgrol's Avatar
sgrol
Pics of chip install described earlier in my gallery. Could not figure out how to post in message.
Old Mar 1, 2006 | 08:44 PM
  #29
the1mg's Avatar
the1mg
Wink
Sgrol,
I think you have to be a supporter of FTE . Just click on someones "blue supporter icon" to join, cost is only $16
Old Mar 1, 2006 | 11:23 PM
  #30
PowerStrokeMe
When you bring up the reply box there is an emblem of a mountain in the toolbar above where you enter the text you are typing. That is to embed an image in your post. You just have to have the URL address of the picture in order to post it.
