What size portable generator would i need to operate a Hobart Handler 135 welder.
The specs on the welder are 115 V, 20 amp, 90 Amps @ 18 VDC; 63 Amps @ 21VDC, amp range of 30 to 135.
I am looking at purchasing a 2500 Watt generator, would this run the welder ?
I think it will, but it'll be close. You'll really be pushing the limit of the generator when the welder is cranked up. Also, keep in mind that generator ratings are often over rated, and will cause problems for you when welding thick stuff. You would probably be better off with a little bigger generator, to be on the conservative side.
For the price you will pay for a generator you should have got you a diesel or gas machine. It would be cheeper to run you a elec. cored from you meter box to run the machine. That if you have it for home use. I would get a 3000 or bigger.
minimum 10,000 watt....check with Hobart/miller or Lincoln.....I emailed Lincoln a while ago about running a stick welder and they said 15,000 watt because anything but an inverter type welder is using a transformer which is very inefficient....welder will not run right with low output generator and you might burn up generator to boot.
I've never had much luck trying to run a stick welder from a generator. Most portable generators idle down when there is no load on them. They can't pick up speed fast enough to supply the initial inrush current demand of a welder as you strike the arc. You wind up sticking the rod.
We use a couple of gasoline driven welders at work and they're designed to run at an elevated speed continuously as long as they're in welding mode (they can also be used as conventional generators).
I guess you could do a little tinkering with the governor on a conventional generator to keep the rpm's up when powering a welder.
I've had poor luck running a welding machine from any low capacity generator. If you want to try your luck, rent out a generator and hook your welder to it.
If your Hobart Mig welder works best when used with solid wire and gas (Argon mix or CO2) and hooked up to a stable high capacity power source.
As others have mentioned, most low capacity (6000 watts and below) generators will drop speed and voltage when you strike the arc, then the generator will speed up and raise the output voltage. This makes welding (especially starting the arc) more difficult than it needs to be.
yes you are very correct on this. the transformer will ruin welders , refrigerators, air conditioners and other sensitive devices.
To weld on an Amish farm I used my Hobart 140 hooked up to a 10,000Kw pto generator on a Kubota turf master 28 Hp deisel tractor. And you could still hear the strain on the tractor.
70 Blue is right. I bought a Miller Bobcat 250 welder several years back for welding and generating emergency power. Works great! All copper wound with copper leads and circuit breaker protection on the AC side.
