wiring problem?
Old Feb 25, 2006 | 07:30 PM
slowring's Avatar
slowring
wiring problem?
so i just finished up my swap i took a 76 f150 2wd and put the body and motor on my 79 f250 frame its looking great and i just flashed it up today the motor ran great when i took it out of the f150 and everything timing a fuel wise is good, but when i started it today in ran awsome good oil presure, good fuel presure but about 3 mins after i started it she just died and now i have nothing no dome light, lights, ingition buzzer or any power to the thing at all. battery is fine, i checked the wiring everything seems good there then i replaced the solenoid right off the battery, and when i opened to door the dome light came on and when i turned the key the buzzer went for about 2 seconds then all power was cut to the cab again anyone have any ideas?
THanks in advance...
Old Feb 25, 2006 | 08:01 PM
Mil1ion's Avatar
Mil1ion
Ground problem.
Remove and clean all the battery connections,cables, & grounding connections.
This includes the starter relay mounting.
Then get back to us.
How did to verify the battery is good ?
Old Feb 25, 2006 | 09:25 PM
73Custom's Avatar
73Custom
I agree with Dennis. Usually there is a ground wire on the firewall to the back of the engine, make sure it's there and tight.
Marty
Old Feb 25, 2006 | 10:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
The batteries they have been making for the last 10 years seem to die with no warning like that also.
Old Feb 26, 2006 | 06:55 AM
User 71024's Avatar
User 71024
Batteries don't usually die 100%, even if they short out a cell they will have voltage, just not the 12 your looking for, but if he has nothing it's more than likely a connection.
Old Feb 26, 2006 | 08:21 AM
tcannon's Avatar
tcannon
The battery could be shorting out. you can get power out of it but when you hit the key and the ower surge goes thru it it shorts out and kills everything.
russs
22
Jan 19, 2024 07:23 AM
dougjohnson72
Dec 10, 2013 10:26 PM
87300SIX
Electrical Systems/Wiring
Apr 18, 2007 12:54 PM
kread
Jun 21, 2004 12:04 AM
