Po174
Old Mar 6, 2006 | 01:50 PM
aquanaut20's Avatar
aquanaut20
I have 2 of these 4.0 OHV engines, 97 (320K) and 92(350K), both of which have exhibited the P0174 code, and both had leaking lower intake O rings, both fixed with a retorque of the intake manifold. But if you want to swap out O2's first that is your call, personally I tend to test the sensor for switching voltage first. If it is working then I look for a cause upstream...
Old Mar 6, 2006 | 03:52 PM
aquanaut20's Avatar
aquanaut20
Testing O2 sensors on the workbench.
Use a high impedence DC voltmeter as above. Clamp the sensor in
a vice, or use a plier or vice-grip to hold it. Clamp your
negative voltmeter lead to the case, and the positive to the
output wire. Use a propane torch set to high and the inner blue
flame tip to heat the fluted or perforated area of the sensor.
You should see a DC voltage of at least 0.6 within 20 seconds.
If not, most likely cause is open circuit internally or lead
fouling. If OK so far, remove from flame. You should see a
drop to under 0.1 volt within 4 seconds. If not likely silicone
fouled. If still OK, heat for two full minutes and watch for
drops in voltage. Sometimes, the internal connections will open
up under heat. This is the same a loose wire and is a failure.
If the sensor is OK at this point, and will switch from high to
low quickly as you move the flame, the sensor is good. Bear in
mind that good or bad is relative, with port fuel injection
needing faster information than carbureted systems.
ANY O2 sensor that will generate 0.9 volts or more when heated,
show 0.1 volts or less within one second of flame removal, AND
pass the two minute heat test is good regardless of age. When
replacing a sensor, don't miss the opportunity to use the test
above on the replacement. This will calibrate your evaluation
skills and save you money in the future. There is almost always
*no* benefit in replacing an oxygen sensor that will pass the
test in the first line of this paragraph.
Old Mar 7, 2006 | 06:09 PM
2classics's Avatar
2classics
MY MISTAKE. it IS a SOHC. Don't know why I said otherwise.
Old Mar 7, 2006 | 06:42 PM
Jharger's Avatar
Jharger
Then follow aquanaut's lead with my comments in mid as you go. I'd be concerned about the intake O-rings on a SOHC if just one side went lean.
dhenthorn
Jun 28, 2011 06:07 PM
matrix845
Modular V8 (4.6L, 5.4L)
Nov 16, 2008 08:03 PM
jmwhelchel
Sep 19, 2008 04:01 PM
Crismon
1997 - 2003 F150
Jul 17, 2006 03:55 PM
PLatreille
Feb 13, 2005 01:11 PM
