PO171 and PO174 "System to Lean" on bank 1 and 2 message
I have a 2002 Ford Explorer Sport Trac with 72,000 miles and the service engine light just came on.
I read the codes with an OBDII code reader and it gives me the codes PO171 and PO174 "system to lean on bank 1 and 2".
Has anyone seen this before and can you tell me what it means and how to correct the problem?
From what I've been reading, most of the time the gaskets do show both sides lean. When it first starts out, maybe just one side. When it gets bad enough, both sides - also the same time when it starts idling bad. Been about a dozen or so posts recently in this forum and some others that I monitor as well.
But sure for troubleshooting, both sides lean you would think about what affects both sides. I'd also throw in the MAF sensor to that logic. And this particular problem may be any of these mentioned issues.
But if there was a bet placed, my money would first go to the gaskets....
Not Sure
Whatever is causing the problem does not seem to be affecting the way the truck runs. It has always had plenty of pep and still continues to get great fuel mileage? I bought a new fuel filter and will try changing that first and checking the fuel pressure, somebody else mentioned checking the screen in the mass flow air sensor as well. I figure I can start with these and try a process of elimination.
Thanks.
Thanks.
JM, also check the airtube between the MAF and throttle body for loose clamps, cracks, etc; any opening where air can enter. Any air leak there will set those codes, since the extra air isn't metered by the MAF.
Check the intake bolts/nuts too. If they're loose that will allow leakage by the manifold gaskets. They are a low torque bolt, something like 89 INCH lbs.
If everything else checks out, then it's time for new intake gaskets.
(Just a personal thought; I think it's the composite intake manifold that warps from heat/cool cycles and causes the leaks, rather than gasket failure. Regardless, new gaskets seems to fix it.)
rocky3539
04-20-2007 03:52 PM
