C6 swap
Old Feb 25, 2006 | 11:28 AM
DictatorDanny's Avatar
DictatorDanny
C6 swap
hi i was wondering how bad it would be on swapping out the e40d in place for a c6. Would it bolt to transfer case and what about linkage and wireing for the e40d. And does anyone know where a can locate a c6 for a 302. My truck is a 94 f150 302 . Thks
Old Feb 25, 2006 | 02:20 PM
jhnhardee's Avatar
jhnhardee
so if your going to be doing a tranny,and rear swap, then to get all this to work, you'll need another computer, you might be able to reflash w/ tweezer or something like that but i'm not up on that. Then when you switch the tranny, go with a transfer case with the speedo in it like the early model 1356, and i don't belive the brakes and stuff will transfer over, but if your doing all this might as well put on a disc brake conversion kit.
