worn out 5.0
Old Feb 25, 2006 | 11:27 AM
ajmorell's Avatar
ajmorell
worn out 5.0
My dad has a 93 F150 ext cab 2wd and is closing in on 170k. The engine is rapidly losing compression, and has needed a valve job for a long time. His plan is to run it until it dies. Well, when it does, I'm gonna take over and rebuild the motor. I really want to stroke it, but have a few questions concerning doing so. First of all, what is my best bet, buying a "stroker kit," or indivudally buying the components. Eventually I want to put this motor into a reg cab short box 2wd and create a street truck (I already have a 4x4 so don't really need another), and would really like a motor that can make it scream. My second question was concerning hi-perf cyl. heads. Are all 5.0 blocks the same...or more specifically, would say trick flow heads for example match up? If anyone could help point me in the right direction that would be great.
Old Feb 25, 2006 | 02:50 PM
jhnhardee's Avatar
jhnhardee
to answer the first question would be if you had all the funds and there was a kit that matched how you wanted to go with your engine then you usually can get it cheaper in a set. The heads should match up with most small block windsors from 60 something to 93. You might have to double check the coolant passages line up.
Old Feb 25, 2006 | 05:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome ajmorell to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 25, 2006 | 07:04 PM
ajmorell's Avatar
ajmorell
Enjoy FTE....and
Thanks, hopefully I'll have more to post about once the old mans motor finally craps out and I get my hands on it!
Old Feb 25, 2006 | 07:39 PM
Dannym's Avatar
Dannym
Doesn't that have the Speed Density fuel injection in it? Won't the SD computer be confused by a stroker modification?
Old Feb 25, 2006 | 08:36 PM
autoparts's Avatar
autoparts
Former Vendor
It looks like the same cylinder head gasket fits a 1970 5.0 and a 1993 Ford 5.0 so the block has stayed the same.
www.RockAuto.com carries several choices of Sealed Power brand Master Rebuild Kits for your engine. We also have Proformance remanufactured Long Block engines for your truck with stock cylinder heads.
Old Feb 25, 2006 | 11:30 PM
ajmorell's Avatar
ajmorell
I honestly have no idea. How do I tell?
Old Feb 26, 2006 | 12:37 PM
ajmorell's Avatar
ajmorell
Well, I have been trying to read up a little bit and do some research and this is what I'm thinking. The only thing I really want the motor out of my dad's truck for is the block. I have no intents of putting the motor back into his truck (the body is showing some wear as well). If I go this route, and decide to put this motor in a reg cab short box (same bodystyle 92-96), what do I need to look for and what do I need to beware of?
Old Feb 27, 2006 | 09:31 AM
Kemicalburns's Avatar
Kemicalburns
well you have a few choices. if you find a 94+ with mass air you will be in better terms. the ecu may still need tuned but its at least drive able. if you go with something from 92-93 and its speed density you can still stroke it but will require a special Grind cam to run with that ecu. and still may require a tune using a tweecer.
check out fordfuelinjection.com
Old Feb 27, 2006 | 12:26 PM
ajmorell's Avatar
ajmorell
so basically from my understanding then, it is okay to stoke it, I will just have to be careful and cautious in my choice a vehicle to put the engine in?
Old Feb 27, 2006 | 01:07 PM
Kemicalburns
correct. you pretty much nailed it. check out that web page as well lots of great info. just think how you want to use the rig and build to that.
MisterMichigan
2009 - 2014 F150
31
Jan 25, 2017 06:42 AM
thompsj0784
Aug 18, 2015 04:30 PM
fordboy97
Mar 28, 2015 11:40 AM
Kijutsu
1983 - 2012 Ranger & B-Series
25
Jul 28, 2006 10:16 AM
desertdave35
1978 - 1996 Big Bronco
Jul 25, 2006 06:52 PM
