body swaping
Old Feb 25, 2006 | 05:55 AM
blueovalblood's Avatar
blueovalblood
body swaping
ok one of my favorite trucks i own isnt actually a truck. it is a 78 e150cheatua van and i love it. it was the first vehichle i had ever driven. so i am kinda attached to it. the problem is the body is literally rusting to nothing. however the engine,drivetrain and chassie are still in remarkebly good condition. so insted of buying bondo by the 80 gallon drum i started looking and realized i could actually remove the entire body from the diveline and chassie. the only problem is i dont know if another body would fit or if i could find one reasonably priced in good condition. so please any one who has done this sort of thing or who knows anywhere or anyone who has referbd bodies or good old ones give some help or suggestions. any advice will be greatly appreciated thank you.
Old Feb 25, 2006 | 12:54 PM
rbohm's Avatar
rbohm
depending on how much work you are willing to do, you can swap another van body on from the same years of your body style(75-91?), or you can swap a truck body on(73-79). or oyu can build your own body. if the cab is in good shape, cut the rest of the body off, and build a box or motorhome style body. upgrade the chassis and suspension at the same time though.
Old Feb 25, 2006 | 01:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Feb 25, 2006 | 03:08 PM
Gene W's Avatar
Gene W
I don't know about being able to swap a truck body onto your chassis. In the later years, the F series chassis is narrower than the E series. Steering layout may be different as well. Like I said, I don't know for sure about your year, but check it out.
Probably be best to find another van and do the swap or find one or more damaged ones to cut body repair panels from to repair the body that you have now if yours is good enough to repair.
Gene
Old Apr 1, 2007 | 12:47 AM
Randy8876's Avatar
Randy8876
rbohm,
What ever came of this? Did you do a body swap, or just repair panels?
dimetimetom
1966 - 1977 Early Broncos
Jul 13, 2013 09:34 AM
troy77
13
Aug 29, 2012 03:43 PM
JOHN2001
17
Aug 14, 2011 12:42 AM
quintcy
Oct 20, 2009 06:44 AM
