VIN decoding help
Feb 24, 2006 | 08:41 PM
VIN decoding help
Feb 24, 2006 | 08:46 PM
VIN Decoding help needed
Hi,
I have a 78 F250 supercab that I have been trying to get decoded with little luck. It seems you guys are in the know so I was hoping you could help.
Vin # X26SKCE9660
WR - 155
COLOR A
TYPE RVW - 1262
BODY - KDM
TRANS -G
AXLE - B 4J
OPTION
42 - 080
Any help would be greatly appreciated,
Thanks
Feb 24, 2006 | 08:52 PM
Vin # X26SKCE9660
X26 - F250 SC 4x4
S =Engine = 400
K= Plant built at = Kansas City
CE9690 = (consecutive build code = Truck # 9,690 Built in June 78
WB - 155 =155" wheelbase
COLOR A = Black
TYPE RVW - 1262 [b](actually GVW - F262) is the truck code for weight rating to body of the truck
BODY - KDM Trim Scheme
K = Broadcloth & Vinyl Seat (LGO Interior)
D = Color interior = RED
M = Supercab Styleside
TRANS -G Automatic (C6)
AXLE - B 4 = Dana 60 4.10:1 ratio
J = Power steering
OPTION
42 - 080
EDIT: DSO Special Order #80 for Cleveland Ohio,Region
Feb 24, 2006 | 08:56 PM
Yes the last numbers are over DSO.. If memory serves me correct
Feb 24, 2006 | 08:58 PM
That means it was the 80th specially ordered truck by and sent to the Cleveland Ohio Region.
Feb 24, 2006 | 09:01 PM
Feb 24, 2006 | 09:02 PM
Thanks, I have nothing else to do
Feb 25, 2006 | 12:36 AM
Thanks for the help Dennis, Your help is greatly appreciated here
Jimmy
Feb 27, 2006 | 03:33 PM
Could you help me out?
vin x15kdh2251
wb 139
color AQ
type x152
body KAM
trans K
axle 16J
Then at the bottom it has
06200 1979 26
I'm sorry I had an extra 0 in the vin
Feb 27, 2006 | 07:58 PM
vin x15kdh2251
X15 = F150 SC
wb 139 = wheelbase 139 "
color AQ Two-tone Exterior >
A = Black
Q = Dark Brown Metallic
type x152 = GVWR code for 6200 lbs
body KAM = Trim Scheme
K = Broadcloth & Vinyl Bench seat (LGO Interior)
A = Black Interior
M = SuperCab code
trans K = Automatic (C6)
axle 16 = 3.50 .1 (Open axle)
J = Power steering
06200 1979 26
26 = DSO = New Orleans
Feb 27, 2006 | 09:41 PM
thanks,, the only question is my truck is black and silver with a 460, lariat. I wonder why it doesn't have the engine code?
Feb 27, 2006 | 09:47 PM
For 79 :
Silver Poly is code J
Light silver Poly is code N
The engine code is in the VIN#. 4th digit.
I didn't do that part because one digit is missing.
There should be 11 digits.
Are you sure that's a Q for colour ?
Feb 28, 2006 | 11:25 AM
Ok I went back out and wiped it off and double checked the vin is
X15JKDH2251
color was AO not AQ
I'm sorry.
Feb 28, 2006 | 11:29 AM
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
