How does one go about cleaning the carbon and crud inside the lower and upper plenum on a 5.0 truck intake? Can they be hot tanked? Does anyone have any tricks or tips? I just hate the thought of putting these cruddy pieces on top of a fresh motor. Any suggestions are appreciated.
Yes, a machine shop can hot tank them and get most all of that crap outta there.
Jerry (water5) had his stockers done and they looked very nice when they came back.
An aluminum intake in an actual hot tank will disappear in short order. The solution eats aluminum. The pressure washer type cabinets are usually used for aluminum items or a large dip tank with an appropriate solution.
if you want to do it yourself, spray them really good with oven cleaner...i had the exact same problem and didn't want to put the nasty ones on a new engine so i coated them up on the inside with oven cleaner, let them sit for a while (24 hours i think is what it was), then rammed a brush in there that i got from harbor freight. if it needed it again, i did it a second time (though the first time got them pretty good. this way is a cheap way to do it yourself. do take into account, if they are aluminum, THEY WILL TURN BLACK on the outside. mine were aluminum but i didn't care b/c i coated them with some high heat rattle can. for a clean intake system and paint, i think it cost me 15 dollars. its up to you for the results you want. i would imagine paying to have it done would do a better job but i was VERY pleased with my outcome.
good luck.
chris
