Cloyes Timing Chains
Old Feb 24, 2006 | 01:04 PM
Munch's Avatar
Munch
I had a question about a timing chain that i had purchased at my local auto parts store. The timing chain is for a 1977 Ford 6.6L. The chain i purchased is not a true roller but just single key way. The stock Ford timing chain in this engine retarded the timing to match emissions. I was wondering if anyone knows if the Cloyes timing chains are also retarded the same way, or are they set at 0 degrees?
Old Feb 24, 2006 | 02:23 PM
tastyklair's Avatar
tastyklair
I'm not positive but I would bet if you purchased a direct replacement for a 77 it is probably retarded like the stock one. I'm sure you could check a listing online to fine one from a 79 and see if it is the same or not. If it is the same as a 79 it would be at 0. If not it is a dog.
