Aerostar Ford Aerostar
MAF question
Old Feb 24, 2006 | 10:18 AM
ken1mod's Avatar
ken1mod
MAF question
Gentlemen,
Does a dirty MAF make cruise mixture richer or leaner?
Ken
Old Feb 24, 2006 | 07:30 PM
B-Aerostar's Avatar
B-Aerostar
I think leaner, because when mine was dirty I got lack of power, and engine knocks. Also it seem to be running hotter.
Old Feb 24, 2006 | 10:26 PM
Lance1601's Avatar
Lance1601
Rockauto has got some MAFs remanufactured by SIA. Look like brand new from Ford (no funny stickers or anything) for $73.79 with a $30.00 core.
Old Mar 2, 2006 | 12:49 AM
93nighthawk's Avatar
93nighthawk
Both.
Originally the Computer will think that you are getting less O2 than in reallity, so it will lean the system, but then the O2 Sensor will detect a lean condition, and the computer will flip flop trying to correct the problem.
Old Mar 2, 2006 | 01:06 AM
Bear River's Avatar
Bear River
Former ******
Yup, flip flopping results in a slightly lean average, with poor performance and economy. I find most MAF equiped systems rely most heavily upon the MAf, and use the O2 for fine tuneing the mix. If the MAF is faulty, it results is wilder fluctuation in economy, but if it passes out of spec, the O2 becomes the primary mixture sensor.
Old Jun 27, 2006 | 03:30 PM
TrickStyle3L's Avatar
TrickStyle3L
Question
I have a small problem and I know its mixture related. When I take a sharp turn and slam the gas, my van cuts off power and the A/F ratio is all the way on the lean side then after the turn is complete the ratio is back to normal/rich. So far I changed the fuel filter, MAF sensor and checked fuel pressure. The problem is still there... so would my o2 sensor cause this leaning out? People are telling me its the fuel pump, but my car starts up fine and handles RPMs all the way up to 6K like nothing.... does anyone think they can solve this problem what it could be?
Old Jun 27, 2006 | 05:50 PM
Bear River's Avatar
Bear River
Former ******
If your O2 sensor has more than 60,000 miles on it, I would just replace it, but I don't think that it is the problem. The MAF, maybe. Fuel pump, quite likely. Electrical problem, very likely.
Old Jun 27, 2006 | 07:23 PM
96_4wdr's Avatar
96_4wdr
broken fuel pickup on pump or broken tank baffles?
or loose air tube fittings between MAF and TB?
Old Jun 28, 2006 | 01:29 PM
VanGo's Avatar
VanGo
Originally Posted by ken1mod
Gentlemen,
Ken
Any noticeable symptoms? My '93 4.0 pinged an awful lot. Mileage was down too. I bought a set of tamper-proof tork bits, removed the MAF and cleaned it with contact cleaner. Pinging stopped in all but the most severe loads.
Old Jun 28, 2006 | 06:24 PM
catalinagoose's Avatar
catalinagoose
Gentlemen,
Ken
When a MAF fails, the fuel mixture will be lean.
