really need help fellas
Old Feb 24, 2006 | 12:43 AM
7FORD2's Avatar
7FORD2
Question really need help fellas
alright fellas this is about a 360. how would oil get in your water? not water in your oil. i reapeat oil in your water not water in your oil. please help fast.
Dustin
Old Feb 24, 2006 | 12:44 AM
gtex's Avatar
gtex
bad head gasket?
Old Feb 24, 2006 | 12:46 AM
gtex's Avatar
gtex
maybe a bad intake manifold gasket could get some oil in the coolant passage as well.
Old Feb 24, 2006 | 12:52 AM
fordeverpower's Avatar
fordeverpower
what kind of tranny cooler and radiator setup do you have?
to explain myself, some radiators have an internal oil cooler and they can leak and oil/tranny fluid gets in the water.
Old Feb 24, 2006 | 01:26 AM
Hypoid's Avatar
Hypoid
Crack in the head or upper cylinder wall, but you would also have signs of water in the cylinder.
Old Feb 24, 2006 | 01:27 AM
ford390gashog's Avatar
ford390gashog
a blown tranny cooler.
Old Feb 24, 2006 | 02:02 AM
7FORD2's Avatar
7FORD2
ok it cant be the tranny cooler cause it has a np435 in it. and there is no sighs of water in the cylinders. so cracked head or a bad head gasket are the only things?
Old Feb 24, 2006 | 09:07 AM
Putt's Avatar
Putt
Another possibility is the oil passage to the heads is a tube running thru a coolant passage in the block. They can crack and allow oil into the cooling system. It is unlikely an intake problem could cause this, since there are no pressurized oil passages in the intake or mating surfaces.
Old Feb 24, 2006 | 12:07 PM
rusty70f100's Avatar
rusty70f100
I had a 360 (D3TE block) that did this. Oil would very slowly seep into the water. It would not go the other way. It was the coolant passage that Putt describes. If you look on page 5 of Steve Christ's book "How to Rebuild Big-Block Ford Engines," it describes the problem and a solution. Basically, you cut the ends off a pushrod, drill the passage, cover the pushrod with sealant, and press it into the passage. As long as it's not losing oil too fast or affecting your radiator pressure, I wouldn't worry about it.
