4.30 gears carrier and pinion bearing life
I have a 2004 f250 4.30 gearing rear end. I replaced the bearings in it three years ago and have covered 35,000 miles since then. 18,000 miles of that was towing. My GCWR is 17.250lbs. The camper loaded is 9300lbs. Ford 75/140 synth fluid. Nothing is overloaded and travelling at 65 on the interstate for extended periods of time towing my diff temperature never exceeded 204 degrees, even in 90 degree weather. So I began to hear some whining back there so I pulled the cover. Bearings looked good but there was slack in the carrier bearings and so I went through the whole thing again. New pinion bearings, new carrier bearings, I had great pattern on the ring gear pinion. Backlash was at 12 thousands which is within spec from Ford for the Sterling. My question is what would cause all that wear in the bearings.? Replacing them brought the thing right back into spec. My backlash when I heard noise was 18 thousandths. I am working it, but I figured it should last a lot longer than what it is doing. I have run it 15,000 miles since the rebuild, half of that towing my camper. It started out at 12 thousandths and it is already at 15 which is the outer limit of specs. Any thoughts would be appreciated.
I can't speak to what your issue is, as I have no idea, maybe a warped housing, or mis-aligned caps? Regardless, I'd expect a hell of alot longer than 35,000 miles out of a set of Differential bearings. I *regularly* see OBS with the 10.25 Sterlings with a couple of hundred thousand miles on the original bearings.
A guy told me tonight who rebuilds rear ends that if I put the right side shim in after the carrier that there will not be enough preload on the carrier bearings. I have never heard of this.. He said that the two shims should be put in the housing then put the carrier in. anyone got any experience with this. I put the left shim in, then the carrier and then the right shim which went in half way easily then I had to get a bronze driver and tap it into place and it was tight, so much so that I thought the shim would break. . Thoughts appreciated thanks
Once you had the carrier in and the bolts tightened down did you set up a dial indicator and pry the carrier with a long bar back and fourth to see if there was any movement on the indicator ? You can't go by just the degree of difficulty of getting the carrier into the housing.
Well I have decided to let the guy rebuild my rear end. I have yukon gears and installation kit coming and a eaton truetrac from summit racing. I will enjoy not having the clutches and LS to deal with and he is going to set it up right. The only problem I am having is that truetrac wants non synthetic 75/90 in it, and the ring gear and pinion wants 75/140. synthetic.
The TrueTrac relies on the friction between its gear teeth and gear housing to provide the limited slip function, so if you use something too slippery, it may not be as effective as a less slippery lube. I'm using a similar LSD in my 9" with 75-140 gear lube, and it grips just fine:
https://photos.google.com/share/AF1Q...ZEOUVmWjRfSFl3
The worm or helical gear type LSDs don't have a preference for synth or regular oils. But don't use a friction modifier like with the clutch type LSDs, as that WILL significantly reduce the friction of the oil.
V8SHO
1997-2006 Expedition & Navigator
03-07-2020 05:24 PM
