you have to take the tranny out and the clutch pressure plate and the fly wheel out the drill two sides of it thread sheet metal screws in it and then pull it out
That truck should have the two piece seal which will require removal of the oil pan to you can remove the #7 main bearing cap. The good news is that the trans can stay in place.
