help!! Temperature sending unit
Old Mar 10, 2006 | 06:51 PM
cougeuph's Avatar
cougeuph
Where is the temperature sending unit located on a 80 300(4.9L)?
I just got my pu back from the dealership after getting a new clutch put in and the temp gauge no longer works. Where is the sending unit located?
Old Mar 10, 2006 | 06:56 PM
havi's Avatar
havi
I'll have the Roast Duck
one on top by the thermostat, and one in the block back below the exhaust manifold passenger side. look for 90 degree rubber boot electrical plugs....red I think.
Old Mar 11, 2006 | 05:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome cougeuph to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 13, 2006 | 11:01 AM
63redtudor's Avatar
63redtudor
Some of them are in the thermostat housing (mostly later engines), but most are actually in the block. Look just below the #6 intake runner & thats where you'll most likely find it.
Edwin
Old Mar 13, 2006 | 12:35 PM
Oscar Meier's Avatar
Oscar Meier
The sensor for your gauge is in the block below the #6 intake runner - I hope your arm bends in two different directions (Take out the starter it's easier to change the sensor)
good luck.
Oscar
Old Mar 13, 2006 | 01:24 PM
quicklook2's Avatar
quicklook2
make the dealership reconnect/fix it.
why would you even think of not making them fix this if they broke it when they were working on your vehicle?
