bought set of lakewood traction bars they did not fit becous there is a block between the spring and the axel witch the bracket are too short the truck is 94 4x4 no lift stock anny other brand out there that will work. not to expensive need some input.
Truck power buy a built 351 lightning motor bore.20 over e-303 cam
edelbrock aluminum heads,30 lb injectors,lincoln torque converter and computer tuning.
you can take that block out... (you'll need to do a shackle flip for it to still ride the same height)
The shackle flip will lower the load capacity of the truck, but seeing your mods, it doesn't appear to me that you're doing much towing/hauling anyway.
