i have 3.73s with 35s and i run in overdrive its a real let down when it shifts. i want to know i have new gears to put in along with 37s. will it hurt trans if i run out of overdrive with 37s til i can get gears in.
Is your T/C stock? That seems to be tthe weak link. Temp guage is a must in my book. It'll tell you alot about how the trannys coping with everything. Heat is what really kills them, and if your T/C clutches are slipping it gets hot. An external filter is also a plus.
You manual say no OD for towing to save the T/C. Beast gave good advice. Is your speedo way off? I bet you are turning about 2k @ 65 mph. There's a calculator somewhere............
