My computer wont fire up!! PLEASE HELP!!!!
Old Feb 22, 2006 | 08:57 PM
FordPickup460's Avatar
FordPickup460
I just went to turn my computer on after it had been sitting off for a day, and the green ring around the power button didnt come on, its sending no signal to the moniter, the yellow CPU light stays on solid and the fans inside the tower spin. I blew all the dust out, cleaned the contacts on the cards with a eraser and put it back together and it still wont start up. I checked all the connections on the back of the tower and it still doesnt work. What can cause this problem?? When I hold the power button in to shut it off the fans shut down, but the yellow CPU light still stays on but is kind of dim. There is no beep or spinning of the harddrive when I start it up. Any help is appreciated, thanks.
3 year old emachines, Windows XP Pro amd athalon 2000 processor.
Old Feb 22, 2006 | 09:03 PM
captain p4's Avatar
captain p4
I don't know how it would've come lose, but make sure the ram is seated firmly in the MB, this will usually happen if it isn't.
Old Feb 22, 2006 | 09:05 PM
FordPickup460
I took it out and put it back in and it still dont work.
Old Feb 22, 2006 | 09:15 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Your power supply might have died...
Old Feb 22, 2006 | 09:17 PM
FordPickup460
Would my CPU and fan still work tho?
By power supply do you mean the plug and cord from the wall to the back of the tower?
Im not very skilled when it comes to computers.
Old Feb 22, 2006 | 09:29 PM
Caplax40's Avatar
Caplax40
Yes, the power supply is the "box within the box" of the computer. I assume you have a tower case so it'd be up top in the rear with all the power cables coming from it. It's usually connected to the case via four screws in the back.
It's definitely a power issue, I'd just replace the power supply with a brand spanking new one. Computers do some funny and usually random things when they don't get enough power.
Old Feb 22, 2006 | 10:12 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Get close to the top back of your PC and take a deep breath through your nose.
(Snif. . . snif.)
Do you smell and 'acrid' smoldering rubber odor?
Like the others said, the power supply is probably saying adios.
Part of the supply can still be putting out voltage, but, not for long.
I also suggest unplugging the PC until you have the replacement power supply in hand. (Safety first.)
Another thought. . . .
(This has happened to me.)
Have you experienced a power outage, recently?
If so, turn off the pc. . . unplug it for a couple of minutes, then try to boot, again.
Old Feb 22, 2006 | 10:21 PM
jake00's Avatar
jake00
sounds like the cpu / tower is working fine, but you have no video signal IE you fried your video card/ onboard video
Old Feb 22, 2006 | 10:30 PM
k460's Avatar
k460
Thats kinda what i was thinking, my hp did that last year
Old Feb 22, 2006 | 11:02 PM
Mil1ion's Avatar
Mil1ion
Shut it off...pull the plug on the power cord > in fact remove all the connections and remove a side panel.
Maybe an IDE ribbon cable or power cable has vibrated loose and won't allow the puter to boot up?
What was your HD boot up order and did you see any of those lights come on ?
Disc A,D,C
Old Feb 23, 2006 | 12:04 AM
Greywolf's Avatar
Greywolf
It's also possible that something (a program, games will do it a lot) that you were running changed the video settings. But I don't like the sound of "Don't hear the hard drive running or anything else".
One thing I ran into a few years back is sometimes the button cell or watch battery that keeps the memory in your bios alive may have run out of juice.
Sometimes you can just replace it and everything comes back, sometimes it has to be pulled and left out for a few days and then be replaced.
In the worst case, a power surge can blow the busses on your mainboard.
Did it shut down normally before this happened, or was there a power outage?
Old Feb 23, 2006 | 07:08 AM
fordloverf2501970's Avatar
fordloverf2501970
usually if the lights come on but nothing happens it is a loose card in the pc causing this, also the hard drive could be toast. the only true way to tell this easy is to put a different hard drive that you know works in a start the boot up. if it boots then rehook up the old hard drive and try it again, fails then it is the hard drive, doesnt fail and it was a loose connection. always back up hard drive at least once a week to perpare for this happening, i have seen new hard drives last less then a month, and i have seen old hard drives go forever acting fine. go figure that out
Old Feb 23, 2006 | 02:26 PM
FordPickup460
I took it to a friends house up the road and we tryed 3 different power supplies and it still does the same thing. As soon as you plug the power in the CPU fan starts and the CPU light comes on, without touching the power button on the computer. If I hold the power button in to shut it down, the fans quit and the CPU light stays on dim untill I unplug it. My friend thinks the motherboard may need to be replaced. The tower was PACKED full of dust, I used a straw and blew all kinds of stuff out, mainly dust combined with dog hair. The CPU fan was so clogged with dust I dont know how it was still spinning. The computer was shut down regularly the last time, and it sat for about 16 hours being off. It usually isnt shut down for more than 10 hours at a time. There hasnt been a power outage for a couple weeks.
Old Feb 23, 2006 | 02:37 PM
polarbear's Avatar
polarbear
That might be the motherboard Trey. One thing too- dust and 'puters don't get along well.
Old Feb 23, 2006 | 02:54 PM
FordPickup460
So to buy a new motherboard, do I just walk into a computer store like Office Max or Staples and say "I need a motherboard" or is there more to it? Would I need to order a specific one?
