Light Help
Old Feb 22, 2006 | 08:01 PM
rpenterics's Avatar
rpenterics
Light Help
The other night I was driving and I started to smell burning plastic, soon my headlights started to flicker then went out. I flicked the switch in and out and my marker and dash lights went out too. Luckily I was close to home and made it back w/o lights. I assumed it was the headlight switch so I replaced it and some blown fuses in the panel - - still no lights. Where should I check next? Thanks for the help
Old Feb 22, 2006 | 08:11 PM
quicklook2's Avatar
quicklook2
what year?
Old Feb 23, 2006 | 08:04 AM
tjc transport's Avatar
tjc transport
i ain't rite
normally when the headlight switch goes, you will have to replace the wiring pigtail to the switch also.
Old Feb 23, 2006 | 12:24 PM
rpenterics's Avatar
rpenterics
Its an '89 F250, I'll check for power at the pigtail are there any fuses under the hood I should check - If so where are they?
Old Apr 12, 2006 | 06:27 PM
rpenterics's Avatar
rpenterics
Finally got it all figured out, ended up being a shorted/melted/burned dimmer switch, bad headlight switch and a few blown fuses. Finally got the mess sorted out and back in working order
