351m/400 valve train
Old Feb 22, 2006 | 11:40 AM
JonLantz Elliott's Avatar
JonLantz Elliott
I have a real problem with two issues. one the number 3 intake valve sticks open on my 351m/400 causing a constant ticking noise and rough idle is there anyway to clean the "varnish" off the stem? two does anybody have vacuum diagram for this engine (1978 F150, 4x4, a/c, manual, no smog pump)
Lantz
Old Feb 22, 2006 | 11:49 AM
Mil1ion's Avatar
Mil1ion
Welcome to the site Jon,
Ticking !
Sometimes a condition called *Exhaust pop* can replicate valve ticking.
This condition is caused by a slight leak between the head & the exhaust manifold.
Valve ticking:
Put some STP, Bardahl,etc *Upper Cylinder lubricant* in the gasoline to help remedy this problem.
If you have the calibration code for your engine (white sticker on right bank valve cover) you can find your diagram here.
http://www.autozone.com/servlet/UiBr...3d800ce605.jsp
Old Feb 22, 2006 | 01:50 PM
1975Ford's Avatar
1975Ford
Lantz, Welcome on board,
I have heard of using a spray bottle and cold water to get rid of carbon deposits, and they had very good results. Couldn't find the thread.
Old Feb 22, 2006 | 02:07 PM
beartracks's Avatar
beartracks
Run a bunch of Sea Foam or Marvel mystery oil throught the carb a little at a time. Also add some to oil.both products work really good at cleaning up an engine.
