Help with roller rockers
Old Feb 21, 2006 | 07:09 PM
Firewolfs79F350's Avatar
Firewolfs79F350
Trailering
I'm in the process of rebuilding my 75 460 and bought some C9VE heads with the screw in studs. Same as DOVE's. Anyway heads didn't have rockerarms with them so I bought some compcam rollers. (they were actually alittle cheaper than stock ones from local autopart store) Anyway I went to install them and check the pushrod length and the roller easily slides off the valve. For those of you that have done this will guideplates cure this? or give me some more info if you know any. Also any idea on pushrod length? Thanks for any info.
Old Feb 22, 2006 | 12:28 AM
monsterbaby's Avatar
monsterbaby
with roller rockers you need guide plates and hardened pushrods.
Old Feb 22, 2006 | 08:21 AM
Firewolfs79F350
Trailering
Thanks on my way to the hi-po shop
Old Feb 24, 2006 | 01:07 AM
Tony G's Avatar
Tony G
I think the comp cams guideplate system has nylon sleeves so that you dont' have to get the hardened pushrods. At least the kit for my late '80's conversion to roller rockers was that way.
Tony G
