Sponsored by: Auxito
O2 Sensor
Old Feb 21, 2006 | 06:55 PM
Latintiger's Avatar
Latintiger
O2 Sensor
Hey guys, whats up? I had my check engine light on for about a week and a half on my 98 f150. it has 135,372 miles on it and it's a 5.4L V8. Well, i took I took it to Midas since it's right behind my office. They told me the oxygen sensor on the right side was the one that is malfunctioning. since it was right below my ac. He was surprised i had gone this long without a problem since they were stock. Anyways, my question is 'how much should I expect to pay for new sensors?'
Midas quoted me 155.22 each. Way too much if you ask me.
also...
is one brand better than the next? or should i just go with the cheapest one that I find?
thanks
Old Feb 22, 2006 | 07:59 AM
projectSHO89's Avatar
projectSHO89
See if they will give you the actual Pxxxx code. That way, their diagnosis can be confirmed.
O2 sensors from Bosch typically run about $50-70 at Autoparts stores. You can replace it yourself with some patience.
Steve
Old Feb 22, 2006 | 11:49 PM
Grsyhands's Avatar
Grsyhands
I agree with Projectsho. The stock O2's are Bosch and the Autozone in my area sells them for between $55-65 per sensor. If you're local Midas (etc) are replacing them you should expect a 20% increase on parts, as at most shops, plus no more than 2 hours labor to replace all 4 (very conservative etimate, should be about an hour). If you were to have all 4 replaced and there is no reason why you should, you shouldn't expect to pay no more than $470 total, plus applicable taxes.
If you plan on driving this (or selling it to one of us) don't go with the cheapest. From a parts perspective (and my buds working in a parts environment) cheap parts are usually that!
I'd stick with the Bosch, they've aways treated me well in my foreign cars and they're stock for the Fords.
Old Feb 23, 2006 | 12:29 PM
gui88ford's Avatar
gui88ford
yea.....40 45 something like that....easy to change.....get the bosch....do them all in your driveway for 180.00
Old Feb 23, 2006 | 08:55 PM
Mr. Man's Avatar
Mr. Man
Just a suggestion, and this is for if your downstream o2s are bad, and this is for if you do not have emissions tests where you live. Go to http://www.rpmoutlet.com/gmo2s.htm , these are o2 senor simulators and are like $60 shipped to your house, COULD be a lot cheaper than buying OEM oxygen sensors...Al you do is hook these up inbetween your sensor and connector and POOF, problem solved. Just my 2 cents though
Old Feb 27, 2006 | 05:08 PM
coldairintake's Avatar
coldairintake
Just went through the same thing with my 97. Did it myself.
Bosch 15716 is the part from Autozone. x-ref the DY832. Bosch makes the sensors for Ford. They are about $45.00 each.
Replace the 2 upstream sensors (before the catalytic converter) You can do it yourself. Autozone will give you the removal tool (with deposit).
If you take the parts to a tech, you should not pay more than 80 in labor.
Old Mar 23, 2006 | 11:22 AM
Latintiger's Avatar
Latintiger
alright guys, i finally got the p code for my truck. I went to my local autozone and got it done as a freebie (wish i knew this before i paid midas $90, oh well ive and learn). the code came out as P0171 systme too lean (bank 1). Now what exactly does this mean? i tried to do some research on it but i felt that i wasnt getting a definite answer, some were saying that it might be a vaccum leak. based off of the code what are the things that i should be looking for?
Old Mar 23, 2006 | 04:44 PM
1997blue150's Avatar
1997blue150
look here for some info that may help.
http://www.obd-codes.com/trouble_cod...gen-sensor.php
Old Mar 23, 2006 | 06:37 PM
wjbv5's Avatar
wjbv5
Bank one refers to one side of the V vs. the other. Bankone is the passenger side bank 2 is the driver side. all you need is a 7/8 wrench to replace the part. Just did all 4 of mine last night in under an hour. Autozone will also rent you a scoket that will make it a little easier. It technically does not cost anything you pay $15 and get it back when you return the tool.
Old Mar 24, 2006 | 02:38 PM
northernowl's Avatar
northernowl
I had the same code P0171 & P0174, Lean code for both banks. After replacing all 4 O2 sensors at about 45 each it cleared the codes.
