Sponsored by: Real Truck
Multivex mirrors - anyone tried them?
Old Feb 21, 2006 | 06:34 PM
RickKimbrell's Avatar
RickKimbrell
I do not have, want, or need trailer towing mirrors on my '06 truck. Hence, I have the regular whatever they are called smaller mirrors. Only complaint I have is that the blind spot is really, really bad on the passenger side. It was the same on my '00 truck and I used those little round mirrors which are OK at best. I started searching for a way to put some type of replacement glass in the mirror similar other vehicles that have that "objects may be closer than they appear" stamped on it. I found that apparently because of the way these mirrors attach to the housing, that type of glass cannot be used in these housings. However, I found a company online that sells a glass that you place over your mirror glass called Multivex Mirrors. I cannot use something that is going to stick out further than do these present mirrors. I was wondering if anyone has every purchased them and how good or bad they are. Thanks in advance for any information.
Old Feb 21, 2006 | 06:48 PM
jake00's Avatar
jake00
how about the small "bubble" mirrors that glue onto the existing mirror?
Old Feb 21, 2006 | 06:50 PM
RickKimbrell
As I said above, they work OK at best. I had them on my '00 truck. I just wanted something better if I can find it.
