Sponsored by: Real Truck
'02 Tranny Leak
Old Feb 21, 2006 | 08:27 AM
rmilchman's Avatar
rmilchman
'02 Tranny Leak
It looks like the leak is coming from where the tranny and transfer unit bolt together. The leak started as a few drops every once in a while to consistent drops anytime I park. If I am remembering correctly I had the same leak last winter and once spring came the problem went away. The truck is an ’02 F-350 PSD 4 speed. Any suggestions?
Old Feb 21, 2006 | 02:27 PM
Fords4Me's Avatar
Fords4Me
Have you checked the bolts on the adapter housing? There's gaskets there as well on both flanges.
Old Feb 21, 2006 | 02:32 PM
rmilchman's Avatar
rmilchman
No I haven't, I didn't realize there was a gasket in there. I'll try to get under the truck tomorrow and tighten them up. Is there a torque speck I should use or just hand tight?
Old Feb 21, 2006 | 02:35 PM
Fords4Me's Avatar
Fords4Me
I wish I could answer that for ya, there's a spec for about everything. On mine (auto) you'd be really hard pressed to get a torque wrench in there. Seems like a bunch of bolts like 16 or something.
Old Feb 21, 2006 | 08:09 PM
rmilchman's Avatar
rmilchman
I'm hoping to get under there in the morning, I'll try to tighten what I can.
Thanks,
Rich
