Let's see your workbenches
Matt
http://i45.photobucket.com/albums/f6...letedbench.jpg
Here's the frame....there IS support on the far right side!
http://i45.photobucket.com/albums/f6...benchframe.jpg
Instead of the 2x4 legs straight down to the floor, bolt the back 2x4 to the wall and angle the legs back against the wall. This keeps the legs out of the way and triangulates the supports
Thanks for everyones suggestions.
Matt
by the way, used the pallet racking for the workbench cost approx $200 including the plywood for the shelves/bench...alot cheaper than the Gladiator workbench in my attached garage.
Hope this helps.
Mitch
this is about as clean as it ever seems to get.
http://memimage.cardomain.net/member...3_147_full.jpg
sublime out.
http://frederic.midimonkey.com/yard/...ean-small2.jpg
Then, I was invaded by slobbish pygmys who decided to shuffle all my tools around and make a huge mess without warning.
http://frederic.midimonkey.com/yard/IM001613.JPG
Erradication of the slobbish pygmys was no small task. They apparently came well equipped for my methods of discouragement. When I bombed the garage with 20 gallons of insecticide, they put on gas masks and laughed at me. I was humbled by their cleverness.
I then resorted to electrifying the garage door handles, as well as the metal tool chest. This resulted in an unfortunate shock to the mailman, who is now on disability for 3 months due to severe muscle spasms in his hand. The slobbish pygmys were still laughing.
With their sharp teeth they gnawed the broom I was swatting at them with down to a stub, almost taking my hands off.
I've resolved myself to coexist with the slobbish pygmys, and offer stale pizza crusts in exchange for free, unscatched passage through the garage/shop to "borrow" tools.
Essentially, it's going to be a 4'high, 6'long, 9" wide cabinet at a right angle to the rest of the workbenches along the "fake" wall I built seperating the two garage bays. The end of this lathe stand will be anchored to that wall, and of course, attached to the floor so it's reasonably stable.
Here is the front panel on the sawhorses, with the internal ribs/shelves/structure being test fitted for doweling and gluing:
http://frederic.midimonkey.com/yard/...d/IM001663.JPG
Doweling is kinda fun. Screwing MDF panels as I've found out is a no-no, if you're attaching to the edge. Guarrenteed split. Dowels and glue. A little more progress:
http://frederic.midimonkey.com/yard/...d/IM001667.JPG
And the internal structure is complete:
http://frederic.midimonkey.com/yard/...d/IM001668.JPG
The next step (tomorrow, if I have any time) is to rotozip out the openings on the large panel these ribs/shelves/structure are glued to, and then dowel and glue on the back panel, flip it on it's bottom, and bolt it to the large plywood wall you see in the right of the picture. In the last two pictures, you are looking at the bottom. The top is open at this point because I won't be using MDF, but instead, maple if my buddy comes through with a couple of 1" pieces. If not, I'll make the top out of MDF and put a piece of steel on top to prevent excessive chipping along the edges.
This strange looking thing will make more sense once it's upright and installed. Essentually the six smaller "cubbys" are going to have cabinet doors in front of htem, and the larger, 2'3" space to the right is going to be "blind" as it will be blocked by the cabinets/countertops I haven't installed yet, along the wall.
Essentially what I'm doing is making workbench "protrusions" into the garage bay, making "workstations" so the tools are more organized. Metal tools towards the front of the garage, wood tools towards the middle, and parts/metal/stuff storage along the opposite wall. And before I install this cabinet I have to remember to hump the engines I have at the back of the garage to the front of the garage, because once this cabinet is installed, anything large behind it becomes permanent!
Anyway, I saw your post about posting links instead of pictures... I'll do so on the garage forum going forward. I never worried about it because the pictures on my my server, on my bandwidth, which I pay for (T1). No cost to FTE. And normally it's up
Anyway, I'll post links, I just wanted you to know *why* I wasn't doing so.
