Carb. adjustment
Old Feb 21, 2006 | 04:27 PM
custom1's Avatar
custom1
Smile Carb. adjustment
I have a 1974 360 engine W/new factory rebuilt 2 barrel carb which with your help is running just about to perfection.
Now it is running very good but if i had to guess I'd say its running a little bit rich by the slight smell when it sits and idles awhile and the small amount of black soot in the tailpipes (which I've never seen any black smoke or any smoke for that matter) and it has a almost not even noticable hesitation on take offs.
but if i were to want to make a small adjustment of the carb,Which way would i screw in the two idle adjustment screws to lean her up a touch? or any other small adjustments to make. I know im just being picky but weve came so far!
Thanks
Old Feb 21, 2006 | 04:52 PM
frdtruckman's Avatar
frdtruckman
turn them in to lean it . i always use a vaccum gauge to adjust carbs , fords seem to run the best a little rich .
Old Feb 21, 2006 | 05:05 PM
custom1's Avatar
custom1
Red face
Thanks a bunch i just diddnt want to go heading the wrong direction with it.
I really dont understand the vacume method you mentioned but id like to learn if you dont mind explaining it.
Old Feb 21, 2006 | 05:43 PM
1975Ford's Avatar
1975Ford
custom1, here you go, https://www.ford-trucks.com/forums/s...d.php?t=464240
Old Feb 22, 2006 | 03:14 PM
custom1's Avatar
custom1
Thanks a bunck thattl do it
Old Feb 22, 2006 | 05:25 PM
1975Ford's Avatar
1975Ford
custom1, enjoy your ride, we all do,
Buck
Old Feb 22, 2006 | 07:43 PM
lowcountry's Avatar
lowcountry
check out this page for useing a vaccum guage
http://www.centuryperformance.com/vacuum.asp
skipper
22
May 1, 2015 03:07 PM
wyckedcombo17
Aug 15, 2014 06:25 AM
bluesky636
Aug 8, 2004 04:56 PM
78fordman
Oct 30, 2003 01:23 AM
cjben
Oct 23, 2003 11:53 AM
