Driveline Question
Old Feb 21, 2006 | 04:13 PM
TwoFiveOh's Avatar
TwoFiveOh
Driveline Question
I'm looking for the best deal on a rear driveline for my 99 F-250 SD 4X4 Super Cab,Automatic, with 6' box. Any suggestions? Stealership says it needs to be replaced, bad vibes at 40 mph and above...Any help appreciated! Stealership says $550.00 not installed. Local used parts not available, at least up to this point. Not sure I wanna go that route anyway. Currently 99,000 miles.
Old Feb 21, 2006 | 04:28 PM
guzzle92's Avatar
guzzle92
Have you checked for any local driveline speciality shops? If it's bent, I guess you would have to replace it but could be in need of balancing or may have carrier or u-joint problems. I think a good driveline shop could even straighten a bent shaft for less than what you're being quoted. I'd sure find a shop and let them check it out first.
Old Feb 21, 2006 | 05:17 PM
TwoFiveOh's Avatar
TwoFiveOh
Thanks, the stealership says the u-joints on either side of the support just past the t-case are shot. The "cardmon bearings" (?) are stiff and no longer have lubricant. I understand that the u-joints are permanently lubed. I will check with local drivetrain folks. I didnt think about them when told about the problem. Thanks!
Old Feb 21, 2006 | 06:49 PM
cangim's Avatar
cangim
would be willing to bet that a local driveline shop would be able to rebalance the driveline if that is truely what is wrong. If the bearings are shot they could be creating oscillations that cause the driveline to wobble due to resanant frequencies. Either way, take it down to local shop.
Old Feb 22, 2006 | 05:54 AM
celjel's Avatar
celjel
I had to replace mine for worn splines on it and it was $550.00 from Ford. I priced getting mine rebuilt and balanced and found that it was only about $50.00 cheaper than getting the new one, but I had the new one the next day and Ford installed it too for that price. It appears that the new one is a lot beefier than the old one was also.
Old Feb 22, 2006 | 06:53 AM
Kwikkordead's Avatar
Kwikkordead
Sounds like that's the best deal, even though it's a little more expensive.
AndeyHall
Sep 24, 2010 10:19 AM
mont974x4
Modular V10 (6.8l)
Apr 13, 2007 10:58 AM
resq302
Escape & Escape Hybrid
18
Sep 28, 2006 07:56 PM
smith200_40
Aug 24, 2006 02:03 AM
EPDP99
Aug 12, 2004 06:11 PM
