Glow Plug Help ASAP
Old Feb 22, 2006 | 04:07 PM
dieself250's Avatar
dieself250
Originally Posted by bassproguy07
. I hooked the light to the positive terminal and then touched it to the spade connector and nothing happened.....
All your plugs are bad. If you want to replace the renturn lines go down to your neer by diesel shop and pick up a renturn line kit
Old Feb 22, 2006 | 04:30 PM
bassproguy07's Avatar
bassproguy07
ok........wasnt what i wanted to hear but thanks for the info!!
Old Feb 22, 2006 | 04:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You need 16 O rings for the caps and fuel resistant line to make the return lines up.
I can't remember what size it is, that was a couple of years ago when I did my last replacement of the return lines.
An extra O ring or four might be worth getting, they are easy to split or drop. Never did find the ones I dropped while doing mine.
Be very carefull with the return caps, they will be a bit on the brittle side.
Also use caution when you loosen the steel fuel lines to the injectors, if the nut is stuck to the line it is easy to twist a fuel supply line.
A bit of PB Blaster and work them back and forth till the nut spins on the line so it don't twist.
Old Feb 22, 2006 | 08:43 PM
Philthy Phil's Avatar
Philthy Phil
Hi all!
Can any one tell me what to use for a replacement connector for my glow plugs? The 1/4" spade connector is too small and the 3/8" too large.
Thanks
Phil
Old Feb 22, 2006 | 09:34 PM
bassproguy07
what kinda truck????
Old Feb 22, 2006 | 09:47 PM
Dave Sponaugle
1/4" female spade connectors should go right on.
Use the yellow ones, the blue ones are to light duty.
Old Feb 22, 2006 | 09:53 PM
bassproguy07
ok dave....whatya think about my glow plugs....sumone up there said theyre all bad u think thats the case? U seem to know a lot about these trucks so i think id trust you over them ne day
Old Feb 22, 2006 | 10:03 PM
Dave Sponaugle
From what you said about the light not lighting when you did the test, yes I would say they are all dead.
Not that strange to see them all dead on the old style system.
It was controlled by a timer and coolant temp.
One plug burns out and the extra amps go to the rest of the plugs for the duration of the timing cycle.
Next thing you know 4 are burnt out and the remaining 4 are now getting twice the amount of amps they are supposed to, so they are toast real soon.
Lots of people here know lots about these trucks, I just say it a little different than most, more often than most AND LOUDER ALSO.
Old Feb 22, 2006 | 10:07 PM
bassproguy07
Ok i think ill change them this weekend...gotta convince the parents to jus pay for it first
Old Feb 22, 2006 | 11:00 PM
Philthy Phil
Thanks for the comeback Dave. The gp's I got from Autozone measure .325 across the male spade. can't possibly fit .25" female connectors. I went to several auto parts trying to find a spade connector that will fit. I suppose I could grind them down to fit , but that goes against the grain. I don't remember the part # they gave me but they are Motorcraft.
ericbskis
Jun 6, 2017 02:45 PM
kneisl99
Oct 8, 2011 06:11 PM
adamzelazowski
Apr 28, 2009 12:29 AM
Scottie250
Nov 15, 2006 09:11 PM
sexwax
31
Feb 14, 2004 01:47 PM
