What is the procedure for setting the air/fuel mixture using a vacuum gauge?
Old 02-21-2006, 11:15 AM
quehele's Avatar
quehele
quehele is offline
Can anyone explain the procedure for setting air/fuel with a vacuum guage? I've never done it this way but I've heard it mentioned in the forums.
Thanks.
Old 02-21-2006, 11:44 AM
beartracks's Avatar
beartracks
beartracks is online now
It's pretty simple. Get the enigne warmed up/choke off. At idle in neutral hook the gauge to a full time vacuum port using a tee. Adjust each idle mixture screw very slowly to max vacuum. You may want to go back and forth a rew times to get it maxed out. Some people will also do it again in gear with someone holding the brake if you have an automatic.
Old 02-21-2006, 11:47 AM
nebechanezer's Avatar
nebechanezer
nebechanezer is offline
i'm just curious, what does it change when you have the truck in gear.
Old 02-21-2006, 11:50 AM
quehele's Avatar
quehele
quehele is offline
Thank you
Thank you Gentlemen. I appreciate the help.
Old 02-21-2006, 01:38 PM
fordraceboy's Avatar
fordraceboy
fordraceboy is offline
it places a load against the motor and therefore drops the idle speed- affecting the vacuum reading at the same time..
Old 02-21-2006, 02:12 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
Set the number of turns on the air / fuel mixture screws evenly. Such as 3 1/4 turn set out on each a/f screw, while maintaining the highest vacuum reading possible.
Old 02-21-2006, 02:19 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
The highest vacuum method works for the most part but it may not be optimal for driveability. You may need to go slightly rich. -Just my 2¢
Old 02-21-2006, 02:46 PM
quehele's Avatar
quehele
quehele is offline
By "slightly rich" do you mean 1/4 turn out...1/2 turn out?
Old 02-21-2006, 03:55 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
Rev your engine and check for a dead spot on the acceleration, then go out a 1/4 turn if you feel the engine should needs it, rev the engine and check if the engine response has improved.
Jsmithblue
09-01-2015 10:29 AM
mgerdau
08-25-2014 06:42 PM
KsCop
22
07-23-2014 10:10 PM
EvoDawg
11-15-2009 03:58 PM
VirginiaWiFinder
12-16-2006 09:25 PM
Quick Reply: What is the procedure for setting the air/fuel mixture using a vacuum gauge?
