General Automotive Discussion
Generator does not charge
Old Feb 21, 2006 | 10:36 AM
jorlee's Avatar
jorlee
I need some tips on how to diagnose this. Had the generator off and tested they said it was good, put it back on with a new regulator and followed the instructions that came with regulator. I can't remember how to test this from college.
Old Feb 21, 2006 | 11:44 AM
dag's Avatar
dag
if its a true generator/regulator set up you might have to flash the field side of the regulator to get it to start charging..... whats the application???
Old Feb 21, 2006 | 11:50 AM
jorlee's Avatar
jorlee
1959 Chevrolet C60 Viking Truck
Old Feb 21, 2006 | 12:07 PM
dag's Avatar
dag
Yeah I remember having the same vintage Mack.... flash the regulator it should straighten it out...
Old Feb 21, 2006 | 04:44 PM
jorlee's Avatar
jorlee
Well that didn't work. Any ways of testing the generator or the regulator? Either on or off the truck.
Old Feb 21, 2006 | 05:04 PM
dag's Avatar
dag
Here's a short blurb I found, it should shed some light for you.....
short story--you can get a 12 volt negative ground voltage regulator at Auto Zone for $20. It is made by "Wells" part number is VR605. It fits a 1958 chevy pickup.
long story--I bought a "B" a couple months ago and the generator was not connected. Tractor had a 12 volt battery. After a few repairs i put a volt meter on the "A" and "F" terminals of the generator while running and to my amazement it had an unregulated voltage output of 20 volts negative ground. Apparently it had been rewound. I had planned on changing out the 6 volt positive ground system to 12 volt, but wanted to keep a generator to make it look original. I went ahead and connected the "A" terminal to the positive battery terminal, thru an amp meter and started up again. 13 volts, 20 amps constant when connected to battery. I then knew i had a winner, just needed a voltage regulator. I went to Auto Zone and asked them for a generic 12 volt regulator the had 3 terminals "Field, Armature, Battery". I guessed a late 50's chevy from Delco would be the most common. To my amazement they had one in stock and it cost $19.90 , Connected the generator "A and F" terminals to regulator and ran a wire from "B" on the regulator to the ampmeter to battery. Polarized by touching "B to A" and then started tractor. 10 amps at 13.5 volts during the first test. Looks like a reasonable cost regulator if you need one. Also can be polarized to be positive ground if you are putting on a production D17, etc.
