ratcheting while turning
Old Feb 21, 2006 | 09:24 AM
roaky81's Avatar
roaky81
While towing 7K lbs and turning at a normal street corner, I feel a ratcheting shake/vibration coming from the rear. I have a 2000 PSD 4x4 with a posi rearend. I'm on the gas pedal just enough to get going, I don't gun it. Is this just the clutch plates in the rearend due to the small turning radius?
Old Feb 21, 2006 | 10:52 AM
Toyman's Avatar
Toyman
Are you using any type of antisway control, or equalizer setup? Does it only do it with the trailer hooked up? What type of trailer and/or load is it?
I am actually thinking that it is the trailer tranferring the noise up through the hitch, you would be able to feel it in the floor sometimes. If it is a leaf sprung trailer and you are making a fairly tight turn it could be the springs and pivots snapping and causing the problem.
Toyman
Old Feb 21, 2006 | 11:37 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It sounds like you need a little friction modifier in the LS rear end. Just get a tube of it and add 2 oz at a time until the vibration is gone.
Denny
Old Feb 21, 2006 | 11:44 AM
roaky81's Avatar
roaky81
Toyman
It's a 25ft toyhauler, I use load equilizer bars and a friction antisway bar. I don't think I hear/feel it when coasting around a turn. I'll pay more attention next time. And I don't notice it when there's no trailer hooked up.
Old Feb 21, 2006 | 11:51 AM
Toyman's Avatar
Toyman
Also look at your shackles and pivots on the trailer, they could be worn causing the noise.
Toyman
Old Feb 21, 2006 | 12:46 PM
The SnoMan's Avatar
The SnoMan
It could also be the tires on the trailer skiding and hopping a bit it a tight turn that is giving you that sensation.
Old Aug 19, 2006 | 12:01 AM
jbawilliams's Avatar
jbawilliams
I also had that problem. I changed the diff fluid to the proper Limited Slip type, and problem gone.
