Another E4OD question
Old Feb 21, 2006 | 07:02 AM
turbonitrous's Avatar
turbonitrous
Talking Another E4OD question
Ok, here is what I got so far.
1.Bought 91 7.3L F350 Superduty was shifting hard 1-2 and no tach and E4OD tranny with 5.13 Dana 80 rear end.
2.Replaced VSS..TPS(throttle position)..and tach sensor.
3.TPS and Tach were bad....I set the TPS at 1.0V at Idle. and reset tranny codes
4.Tranny now shifts much better and smoother.
Two questions
A. what controls the kickdown on the E4OD...I think it should be kicking down earlier instead of lugging down so far. Is it RPM related or TPS or something different.
B.Someone check my calculations
E4OD OD has a .71 ratio( I think)
I have a 5.13 rear end with 235/85/16 tires 55mph@2100rpm
I want 4.10 gears in the rear...I have it calculated that I should run about 65mph at 1900-2000 rpm. what do you think??
Oh yeah one more thing...the way I figure it It should shift alot different just with the 4.10 gears too.
Old Mar 3, 2006 | 09:02 AM
turbonitrous
Cool
Well here is an update for you all...Since my last post..the truck has been shifting fine and doing well until last night...My tach suddenly quit working and thenI checked my TPS and I don't have any voltage going to it....What The #$R%!!! Somewhere I have an electrical problem which is probably root of all the problems. I also noticed my battery dummy light occasionally flashes.UNTIL YOU TURN ON THE LIGHTS OR ANYTHING ELSEE THAT CAUSES A i DRAW.
I have 14.3 volts at idle which is good.
I am trying to lay my hands on a wiring diagram for a diesel
What Engineer thought it was a good idea to put computers in these trucks anyway..
If anyone has had anything similar please respond it may save me some time
End result is the tranny is in LIMP mode again
DarkNite
Nov 3, 2010 05:22 PM
dchamberlain
Feb 24, 2008 02:31 PM
Xyzzy
3.8 & 4.2L V6
Apr 24, 2007 09:27 AM
Riata_Ag
18
Apr 17, 2007 04:41 PM
5x5F150
Oct 28, 2004 03:12 PM
