starter drive removal
Old Feb 20, 2006 | 08:48 PM
bobfl's Avatar
bobfl
Question starter drive removal
I posted this question on the Y block forum but have not received an answer as of yet.
This may be a dumb question, but how do you remove the drive assembly from the starter motor shaft? My starter is shot but the drive assembly seems OK. I see a pin through the end of the shaft but the "collar" partially covers the pin. This is for a 1962 F350, 292. I have a shop manual for the 62, but it in hiding at this time !!!
Thanks
Old Feb 20, 2006 | 09:26 PM
jd_sylvia's Avatar
jd_sylvia
Bob
I just replaced my complete starter and it came as a complete assembly.
Is there a reason why you want to remove it?
If the starter is shot I would think that the drive is not to far behind it. I would recomend a complete replacement.
just my .02 worth.
jd
Old Feb 20, 2006 | 10:17 PM
gangstakr's Avatar
gangstakr
Hey bobf1 can you do me a favor and post a picture of the complete starter drive assembly and all, I need to see if I picked up the right one from a donor truck. I've never done one of theses starters before and have not pulled mine apart yet. a picture worth looking at for me.
thank you
Robert
Old Feb 21, 2006 | 07:31 PM
bobfl's Avatar
bobfl
Originally Posted by jd_sylvia
Bob
just my .02 worth.
jd
From looking at NAPA's site it seems to come without the drive. Where did you get yours?
Old Feb 21, 2006 | 07:33 PM
bobfl's Avatar
bobfl
thank you
Robert
I can do that, but it might be a few days before I can do it.
Old Feb 21, 2006 | 08:05 PM
jd_sylvia's Avatar
jd_sylvia
I got mine from Kragen Auto Supply, That would be Checker or Shucks for you I think.
Mine is also for a 352, If I remember correctly you had a six.
Good luck
jd
Old Feb 21, 2006 | 08:25 PM
gangstakr's Avatar
gangstakr
thanks Bob I'd appreciate it.
Old Feb 22, 2006 | 11:54 AM
bobfl's Avatar
bobfl
I put a picture of the starter in an album called STARTER. If you use the filters to find it use 1962 F350 4x2
Hope this helps you.
Old Feb 22, 2006 | 02:22 PM
gangstakr's Avatar
gangstakr
Thanks Bob that helped out I guess I have the right one.
staying low for now
Robert
Old Feb 23, 2006 | 05:03 PM
bertha66's Avatar
bertha66
Bob, if I remember right, at the end of the shaft there is a pin going through the shaft, at the wnd of the drive unit there should be a spring loaded collar over the pin. pull back on the collar and take out the pin and the shaft will slide off.
Allen
Old Feb 23, 2006 | 08:40 PM
Young_unn's Avatar
Young_unn
KEEP THE DRIVE!!!!!! its always useful to have a spare one BELIVE ME, anyways, the whole drive assembly can be pushed down and the pin will just slide out, BUT you need alot of force to puch it down enough to ge the pin out.
Old Feb 24, 2006 | 06:33 AM
bobfl's Avatar
bobfl
I guess I have not yet used enough force. It will not slide back using hand power. I'll rig up a press and see if it moves.
Bobfl
Old Feb 25, 2006 | 06:49 PM
bobfl's Avatar
bobfl
Talking It's fixed
I picked up the starter on Friday from NAPA it did come without the drive. To remove the drive, as suggested by others, the front collar must be pushed back to remove the pin. It took quite a bit of force. I have a big woodworking vise so I put the starter in it to push on one side of the collar and a big clamp on the other side so that I could push it evenly, then drove the pin out. I just reversed the operation to put the drive on the new starter. I put the starter back in and it started right up.
Thanks for all the input.
Bobfl
Old Feb 27, 2006 | 12:23 PM
Young_unn's Avatar
Young_unn
Bobfl
Good luck i had starter trouble for 3 months, i ended up getting used starter drives and rebuilding them because i couldnt get one. and because new starters dont come with them. but macs antique auto does sell the starter drive.
i to used a woodworking vise to pull the ring down and get the pin out
Good Luck
Old Aug 1, 2008 | 07:11 PM
coop923's Avatar
coop923
I realize that this is an old post, but I'm doing this today and checked here for a reference. Just an update; I got a new starter from Napa and it does not include the drive ($87). Kragen lists a starter for $87 w/o the drive, and $130 w/drive. Autozone told me that they couldn't even get it, but lists a rebuild kit. My insulation appears to be shot though.
