engine swapout
Old Feb 20, 2006 | 07:55 PM
nx_1701_d's Avatar
nx_1701_d
Question engine swapout
i have a 81 f-100 that i'm replacing the 302 in. i thinking about putting in a 351, and i'm not sure of what changes i'll have to make. any help would be welcome
Old Feb 20, 2006 | 08:05 PM
RacinNdrummin's Avatar
RacinNdrummin
Put in another 302. 351w's are highly overated, especially on this site. There is alot more parts availible for the 302 and can easily make more power than a 351w. I you plan on pulling a stump out of the ground, sure, get the 351, if you want performance, get an 88 or so HO 5.0 and put a carb on it. Youll smoke most things out on the road, an f-100 doesnt need any torque to get moving, its a light truck, the 302 revs higher than a 351 and will have the power when you need it with the right gears.
Old Feb 20, 2006 | 09:10 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Feb 21, 2006 | 09:28 AM
Sycostang67's Avatar
Sycostang67
If you are swapping in a 351W, all you should need to change in the truck is the exhaust hookup to the manifolds/headers. The 351 has a taller deck height, so the pipe may need to be lengthened to reach up a bit higher. Make sure the 351 has the correct oil pan to go in your truck, as the 302 pan will not fit a 351.
Old Feb 21, 2006 | 05:51 PM
nx_1701_d's Avatar
nx_1701_d
ok thank's. i'm just wanting something that runs goods and is easy as #@!! to work on. now if i can find a good 302 to put in it
Old Feb 21, 2006 | 05:59 PM
13MWZ's Avatar
13MWZ
I was just at O'Rielys asking about rebuilt engines to replace my 351W HO. A long block out the door was just over a grand not including the $310 core charge. Comes with a full gasket set. I added a new water and fuel pump, cap, rotor, plugs, wires, sensors and sending units, oil pan (long block doesnt have one and my old one is beat up) oil, oil filter, and a few other nick nack stuff and with the core charge came out to just over $1700. Not too bad of a deal I dont think. Might wanna check them out or a similar store in your area.
48 Steel
Oct 29, 2007 12:15 PM
61 uni
15
May 3, 2007 12:58 PM
hoover85
New Member Introductions
Mar 16, 2007 12:10 AM
slmann
Missouri Chapter
94
Dec 10, 2006 09:28 AM
tuono
Feb 8, 2004 08:03 AM
