No Heat
Old Feb 20, 2006 | 06:35 PM
jasa's Avatar
jasa
Cool No Heat
hey guys
on my 92 E150 I just bought, the blower fan did not work. I fixed that but the heat temp was low. Today I replaced the thermostat and checked the hoses, now the check engine light stays on and the heater fan does not blow out of the vents. Can anyone help me
Thanks
Old Feb 21, 2006 | 09:47 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by jasa
hey guys
Thanks
Where is the air blowing from, if at all? If it's coming out the defroster vents, you probably have a loose/open vacuum line that goes from the intake manifold through the firewall to the heater control head.
For the CEL, look for connectors or vacuum lines you might have overlooked or accidentally knocked loose while replacing the thermostat. It could be the same line as for the heater. If nothing obvious is found, pull the codes. Instructions are at www fordfuelinjection com (add the dots). Once you have the codes, post them here for assistance.
Once you have made a correction to something that may have caused the CEL, make sure you reset the computer by disconnecting the battery for 15 minutes or so.
Please specify which engine and transmission your van has. It's important for locating the correct service info.
Steve
Muddbugn1
Aug 22, 2013 08:01 PM
EconolineFan
Mar 13, 2012 02:36 PM
zorro
May 30, 2006 09:36 PM
boogerbutt
Dec 7, 2003 05:27 PM
Fordcr
Jun 8, 2003 08:01 PM
