How does kickdown tie to carb?
I recently bought a 69 f-250 ranger camper special with 390 2bbl carb. The kickdown rod from tran is just sitting up by the carb, not connected to anything. I'm going to install 4-bbl edlebrock and am looking to find out how this rod originally attached and if it needs to be changed.
You may have to do a little fiddling with the bends in the rod to get it to hook up right. Nothing really hard but with an aftermarket maifold and carb, the height and reach are a little different.
I think it attaches to the thing with the ball on it... attached to the throttle linkage side of the carb. has a small spring attached to it so you can adjust how soon it will engage the rod.
if you are going to switch to an Edelbrock or other 4v you will have to lengthen the rod somehow. I had two laying around so I cut a piece out of one and welded them together.
The idea is to adjust the kickdown linkage to where it moves back when you have your foot fairly into it. I set mine to kick down when the secondaries open (higher rpm=more vaccuum=better carburetion with everything open).
Once you get the carb and adapter, it should be pretty self-explanatory. You also may have to do some fabrication with your throttle linkage because the Edelbrock carb is quite a bit wider than the stock carb. Also, the four barrel will sit farther enough forward on your engine that your throttle linkage may have a bit longer stretch to the carb than before. This is something that you do not want to "make fit" because it may lead to stuck throttles--not sure, but this happened to the guy I bought my '67 LTD (390 4v) from.
