need advice about shocks
Old Feb 20, 2006 | 12:31 PM
Kioke's Avatar
Kioke
I think my 96 4WD F150 could benefit from new front shocks.
I'm not planning on doing any offroad, and I'm not a performance junkie...just looking for a decent quality replacement shock at a reasonable price.
any recommendations?
and is this an easy DIY project?
thanks
Old Feb 20, 2006 | 01:15 PM
Lazy K's Avatar
Lazy K
If the front end is bouncy then a set of shocks will transform it. Have a look thru the list of sponsors here and you should find some that list shocks. It should be an easy job to do yourself. Only a jack and a few wrenches needed.
Old Feb 20, 2006 | 01:45 PM
coppertales's Avatar
coppertales
I have a 95 150 4x4...
and I replaced the whole set with Monroes, I think. I installed the air adjustable on the rear. They have worked just fine. There is two on each side in front, you know........chris3
Old Feb 20, 2006 | 03:43 PM
wassabe's Avatar
wassabe
I've had good luck with KYB's. I bought my 88 F250 used in 1995 with KYB's already on the truck. I had them replaced a few months ago at Sears. They were on sale and Sears was offering free installation. I bought the Gas Adjust and I think they came with a lifetime warranty. I helped install a set of KYB's on a truck about 15 years ago and it was a little tricky because they came compressed and required us to release the tension with a string that comes with the shock. It wasn't difficult but it wasn't as easy as some other brands. Good Luck.
Old Feb 20, 2006 | 04:35 PM
77bigblock's Avatar
77bigblock
I always go to AutoZone and buy the $30 ones. They have a lifetime warranty, and they ride nice, so I'm happy.
Old Feb 20, 2006 | 05:13 PM
Kioke's Avatar
Kioke
do I need to replace anything besides the shock, such as bushings, washers, etc?
thanks
Old Feb 20, 2006 | 05:33 PM
Galizien's Avatar
Galizien
how many miles does your truck have, if you have alot, I would change the bushings if they are factory.
I always like replacing cheap wearable parts while I am ripping through that certain section anyways.
Old Feb 21, 2006 | 11:58 AM
Kioke's Avatar
Kioke
truck has 88K miles.
another thing...it's a 4 x 4, with manual locking hubs...it seems to only have one shock per side on the front...I thought there was supposed to be 2 per side???
Old Feb 21, 2006 | 12:17 PM
chrono4's Avatar
chrono4
only 88k?or 188? i think that the 2 wasan option
Old Feb 21, 2006 | 12:41 PM
Kioke's Avatar
Kioke
the truck is a 1996, and it has 88,000 miles, thanks
