choosing a carb spacer
Old Feb 20, 2006 | 08:41 AM
albcasummit's Avatar
albcasummit
Need some help. This is probably a stupid question...My 390 has the stock cast iron 4v intake manifold and I have a holley 4160 carb. I need a spacer so the accelarater pump will clear the top of the manifold. My question is do I puchase a spacer that is open or one that has 4 holes in it? Should I get one thats metal of phenolic? Thanks in advance guys
Old Feb 20, 2006 | 11:45 AM
mdjohnson's Avatar
mdjohnson
I would use one with four holes in it.
Old Feb 20, 2006 | 06:46 PM
LxMan1's Avatar
LxMan1
A 4-hole phenolic will run the best and help keep heat from boiling the fuel in the summer.
Old Feb 20, 2006 | 09:58 PM
Ford_Six's Avatar
Ford_Six
You need to use a 4 hole with that setup, a single hole will whistle and make the truck run poorly.
