410 and problems
Old Feb 19, 2006 | 11:34 PM
RustyTrustyF150's Avatar
RustyTrustyF150
Question 410 and problems
Just running this past someone to see what they think ,,, been useing ten percent ethenol blend gasoline in my 410 FE and had some light ping at times so i tried premium 92 or 93 octane gasoline in it . drove home not noticing anything.Next day 410 runs like a diesel,(SMOKES ) wont idle good ,but will run ok on the road , so i tried a new power valve in the 600 holley , didnt help . Dont smell gas in the motor oil ,no noticable puffing out the tailpipe or intake or valve covers , choke is wide open , All i can think of yet is to drain out all the gas and put in fresh again and check compression just to see if i burnt a hole in the piston ,,, or gascap not venting ?
I can crack the throttle open and the engine rpms are right there and no lag so if anyone has ideas here feel free to message ,,, thanks
Old Feb 19, 2006 | 11:51 PM
Putt's Avatar
Putt
It seems to me that ethanol is tough on standard rubber hose, you might check hose condition, could have fed some material into the carb. Also you said it smokes like a diesel and then no noticeable smoke at the tail pipe? Does it or does it not smoke??
Old Feb 19, 2006 | 11:58 PM
RustyTrustyF150
it smokes at the tailpipe , all rubber hoses were renewed and ok.
Old Feb 20, 2006 | 08:44 AM
Putt's Avatar
Putt
Blue smoke or black smoke?? BTW if your Holley was built after 1992 it has factory power valve protection. Do you have the plastic floats? Could be one has sunk causing rich condition, altho it sounds like accell is OK. Alcohol can remove oil film, it could be something has been damaged from lack of oil in the right place.
Old Feb 20, 2006 | 10:37 AM
fasttexan's Avatar
fasttexan
My first guess would be intake gasket.
Old Feb 20, 2006 | 12:52 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I'm far from an expert on the subject but was there any water or moisture in your tank before you added the ethanol? As I understand water makes gas and ethanol seperate and the contaminated fuel makes formic acid which can harm rings and cyl bores. This possibly is what may of happened. Like I said I'm no fuel expert but had a bud of mine ran into the same problem. Just a thought.....
G.
Old Feb 20, 2006 | 08:24 PM
RustyTrustyF150
good idea , only i have been useing ethenol blend ever since it came out on the market and the alcohol absorbs moisture and burns it so i dont think that idea works either , and this is a near fresh overhaul with 3 thousand miles on now ,,,
Old Feb 20, 2006 | 11:24 PM
Hypoid's Avatar
Hypoid
Originally Posted by RustyTrustyF150
...had some light ping at times so i tried premium 92 or 93 octane gasoline in it . drove home not noticing anything.Next day 410 runs like a diesel,(SMOKES ) wont idle good ,but will run ok on the road...
I'm still back on the basic things:
How much change in Octane? 85 to 93?
What color was that smoke?
It belches smoke at start-up. What about operating temp?
A compression check sounds good, read the plugs while you are at it. It's JMHO that the Ethanol is a non-issue. Put that aside and all you have left is the engine's mechanical condition and tuning. It could be a slug of bad (old maybe?) gas, but that's pretty obvious pretty quick.
Old Feb 20, 2006 | 11:39 PM
RustyTrustyF150
i probably went from 85 octane ( super ) to 93 which is premium , and its a almost black smoke coming out of the tailpipe right at startup and is continuous ,the thermostat is a 180 and the heat gauge works/ shows the temp gauge at center so its in operating range . I am going to spray some starting fluid around the intake manifold gaskets to check for vacum leak then check compression first and if that is ok then drain out the fuel .
Old Feb 21, 2006 | 12:03 AM
Putt's Avatar
Putt
Black smoke generally indicates an over rich condition, not an internal engine problem.
Old Feb 21, 2006 | 12:19 AM
Hypoid's Avatar
Hypoid
While you are at it install fresh plugs, check the rest of the ignition. Make sure everything is up to snuff.
Old Feb 21, 2006 | 01:52 PM
RustyTrustyF150
OK , found something , Holley is dripping fuel on the underside of it , maybe the accelerator pump diaphram is shot ?
Old Feb 21, 2006 | 05:45 PM
RustyTrustyF150
Thumbs up
I was going to try another carburator on brownie just to see through process of elimination i could find problem when i see dripping fuel under the 600 holley ( second time it was off ) the first time it wasnt dripping fuel ,,, so i put in a napa renew carb kit and happy days problem solved . thanks for the ideas .
