Block prep. instructions
Old Feb 19, 2006 | 10:55 PM
know_fear's Avatar
know_fear
Lightbulb Block prep. instructions
Check out this link http://sa-motorsports.com/blockdiy/blkdiy.pdf about block prep./polishing. How many of you put this much work into it? Is this something that should be done for an everyday driver or is it only if your gonna rev it's guts out? Specifically the part about rod buffing.
Old Feb 19, 2006 | 11:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
I remove all of the casting flash, stress riser, and parting lines but I don't polish everything. I do that on any engine I build. That article goes way to far in many areas but they are trying to show everything that CAN be done with their abrasive kit but not necessarily what SHOULD be done.
Old Feb 19, 2006 | 11:12 PM
know_fear's Avatar
know_fear
According to the article, it sounds like the parting lines on the rods are the most important flaws to be removed. Would you agree?
Old Feb 19, 2006 | 11:22 PM
Bdox's Avatar
Bdox
On your daily driver it's really not too important. But if it's going to be subjected to extreme rpms, yes. But, if you do it you should balance the rods (make them all the same weight,) and have them shot peened.
Old Feb 20, 2006 | 01:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
I would agree, but I have seen a number of rods that failed because of other stress risers like improperly installed rod bolts. One of the reasons NOT to replace the rod bolts.
Old Feb 20, 2006 | 10:01 AM
Bdox's Avatar
Bdox
On the subject of rod bolts, I am a little leery because of having seen a couple of rod bolt failures. I was brought a Cadillac motor that was recently rebuilt by a very reputable mechanic and determined that a rod bolt had broken and decided that the bolt had been overtightened. I'm sure he did not do it, but had he taken a few seconds to measure the length or diameter he would have found it. I saw the same thing on an old ****** four which was beyond repair. That one was done by the owner. So if an engine has ever been apart, or may have been, I always scrutinize the rod bolts.
Old Feb 20, 2006 | 11:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Postmortems are always something I enjoy doing.
