cleaning plug wires
Old Feb 19, 2006 | 07:19 PM
78 Ranger's Avatar
78 Ranger
cleaning plug wires
what is the best way to clean plug wires without ruining them. it is only old slime and oil. thanks
Old Feb 19, 2006 | 08:17 PM
Beechkid's Avatar
Beechkid
If we're talking grit here, put on some rubber gloves, and with a rag filled with hand cleaner, rub each wire down, a quick spray with water and you're done. Otherwise simple green or Gunk foaming engine brite.
Old Feb 19, 2006 | 10:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
If they are heavily oil soaked replace them.
Old Feb 19, 2006 | 11:24 PM
Bdox's Avatar
Bdox
One of the few good uses for WD40, the solvent in it is a good cleaner and it won't hurt the wires.
Old Feb 20, 2006 | 07:13 PM
78 Ranger's Avatar
78 Ranger
what would brake cleaner do
Old Feb 21, 2006 | 08:06 AM
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
WD-40 is all you need. Brake clean is hard on rubber, it promotes drying it out. Try the WD-40 with a rag trick like mentioned above, it is really the very best way to clean them. WD-40 is an amazing cleaner....tar from your paint, grease from parts, adhesive from stickers...and so much more. No garage is complete with at least 5 nearly empty cans of WD-40 laying around....
