Rear end identification
Old Apr 28, 2001 | 06:13 PM
blaxuede's Avatar
blaxuede
Here's the tag off of a '77 rear end. Can you tell me if it's a 9" what gear ratio?
IT's goes something like this
WDM-BC2 7CD
3 00 9 386D
THNKS
Old Apr 28, 2001 | 06:22 PM
areimus's Avatar
areimus
im not shure if its a 9 rear end but i think its ggot 3.00 gears
Old Apr 28, 2001 | 07:40 PM
jkt's Avatar
jkt
Is there a COVER that bolt to the back of the housing? if so, then you dont have a 9in., If you can remove the whole front center peice and there is a cover welded to the back of the housing then you have the 9in. Not sure about gear ratio. Hope this helps
Old Apr 29, 2001 | 12:00 AM
blaxuede's Avatar
blaxuede
It does have the welded back plate. And the pinion gear is unboltable from the rest of the third member.
Old Apr 29, 2001 | 06:50 AM
Nathan's Avatar
Nathan
